naku dba eps yan crv na yan, pano maging stiff or heavy ang manibela nyan, ibig sabihin electronic problem na yan. that's a new problem na.
They said they'll try to fix it till tomorrow, if it can't be done sabi nung SA na kausap ko pahiramin daw muna kami ng car sabi ko kasi susunduin ko si misis sa airport on Monday. Pero di nya sinabi if on that day lang ba nila ko pahiramin ng car or till mabalik sa min yung unit. I hope it's not just empty words.
anyone can fix this problem
already try the tips in this forum and youtube nothing happens
usb mp4 files
Just got the CRV back from the detailing shop. Availed of C.Quartz coating for 10.5k at ATMT Car Care. Let's see how this stacks up vs the regular carwash and wax regimen.
That is why some people avoid buying the first batches of a newly released model ...
Solved na stiff/heavy steering wheel. They deliberately tightened the steering wheel to see if the knocking sound will be fix. Unfortunately nandun pa din. The problem is nakalimutan nila ibalik sa normal setting yung stiffness ng steering wheel kaya matigas sya when i drove it. They just adjusted it through computer and its now ok.
as the name implies. detailing or cosmetic detailing or automotive detiaing is improving appearance inside and outside. paint detailing's goal is making the paint look perfect.
protection via wax, sealant, coat, film are different ways to protect the detailed vehicle.
best free photo upload sites
Glass coating keeps your car shiny and protects it from swirl marks and hairline scratches, so basically it has the same effect as regular waxing.
Pros - you just do it once and you're done. Cons - expensive, and tbh it doesn't look that different from a car without glass coating.
from experience, glasscoats/ceramic coats aren't really an end-to-end solution to scratches or swirls. swirls can still develop (and be seen in spotlight/sun) with improper washing technique.
otherwise, they do make cleaning much easier and our dark grey paint stays cleaner for longer between washes.
to the true-blood aficionadoes, "every little bit helps".
to the everyday person, "it doesn't matter if there are swirls or not".
