120 hp CRV drives like a 2.4 Fort - sufficient and never lacking but doesn't have the extra oomph for spirited driving under a full load.
Conservative tune Lang Yan. Ilan Lang itinaas. Umaabot ba Ng 250k km Ang average NCR car owner sa 5yr ownership.
Sent from my Mi A2 using Tapatalk
190hp / 400Nm CR-V would be something. Even a 30 hp bump would be great. But I think I'll stick to stock for now.
The nit I want to pick the most with the diesel CR-V is the constant shifting. In urban settings it feels like it shifts a thousand times before you get to where you're going. S mode minimizes that but still, heck of a lot of shifts.
Not really an MT vs AT issue doc. It's just the design of the powertrain. Makes use of closely spaced ratios to make the most of the narrow powerband and modest output. Makes for exceptionally efficient fuel consumption paired with decent performance.
I don't mind having to trade a bit of fuel efficiency for more power and wider ratios. Something the 160 ps version may have addressed.
Had this serviced at 15tkm before the lockdown. Now it's at ~15,800 lol.
2018 2.0S CRV now almost at 40,000 km. No issues with the transmission so far - silky smooth and responsive. But really just doesn't have the torque of the diesel.
Hi guys. Just want to ask for you expert opinions[emoji5]Since the start of the pandemic, been using our crv once or twice a week lang. Last PMS was June 2020. Mileage between last PMS up to today is around 1k kms. Checked the engine oil and it's still clean and clear. Need ko na ba sya pa PMS kahit di masyado nagagamit? Out of warranty na pala sya. Thanks!
Sent from my SM-G996B using Tsikot Forums mobile app
3.5 years na Sir Egan101. Heavy PMS na daw sabi ni Honda. Need to change din the fuel filter.
Gas or diesel yung CRV mo? Check your owner’s manual for the suggested services based off distance traveled. However, keep the oil changed at least once a year. Kung gas yan CRV mo, look in Lazada for a Honda-spec 0w20 FS oil or similar (Amsoil).
Since you’re working from home, I suggest that you drive the CRV around your location at least once a week for around 30 minutes. These would keep the fluids circulating and the rubber parts from hardening.
2.0S Diesel Sir Egan101. Ganon na lang ginagawa ko. Drive it around makati or bgc area paminsan minsan. Will do the oil change this or next month. Thanks for the the input[emoji846]
Will go for the fully synthetic Sir Papajamba. Thanks[emoji4]
