Page 435 of 442 FirstFirst ... 335385425431432433434435436437438439 ... LastLast
Results 8,681 to 8,700 of 8838
    May 2017
    #8681
    Quote Originally Posted by rvn View Post
    Meron na ba sa inyo nasira yung fan motor?
    Dun sa akin, honda city 2014, nag-oeverheat daw nung isang araw, 'tas nung tinignan, hindi umiikot yung fan sa radiator, pareho.
    Pinalitan sa Honda Kal ngayon, 14k daw gastos.
    Anyone had a similar experience?
    14k pesos??? That's highway robbery bro! Sa amin mga 1k lang ang aabutin nyan using a good china-made fan.
    Apr 2015
    #8682
    Salamat sa replies. Nagbackread nga ako, at may apat ata na nagsabi na nasira fans nila for 2014 Honda City.
    Yung sa akin, pinagawa na ng kapatid ko sa Honda Kal kanina.
    Motor, Fan Radiator = 5,641
    Motor Cooling Fan, Condenser= 5,641
    Labor = 1,920
    After 10% discount sa labor at 7% discount sa parts, 12,231 ang total expense. 6 months warranty nung bagong parts.
    Dec 2014
    #8683
    Labor = 1,920
    Ano usually signs sir pag sira yang dalwa na yan?
    Mine will be 5 years na sa January, hindi masyado nagagamit 20k pa lang odo.
    Baka di ako aware sira na pala, bigla ako itirik
    Feb 2010
    #8684
    I asked same question sa trusted mechanic ko kung ano symptoms ng aux fan when about to fail. Sagot niya is to just wait until it conk out.....hehehe
    Overheating ang maging problema jan pag nasira ang aux fan.
    Your 5year old car is young compred to mine. I have gm1 and my aux fan is still running good.
    #8685
    Labor = 1,920
    ah! you purchased two fans!
    kaya pala mahal.
    #8686
    Quote Originally Posted by polar01 View Post
    my 1997 sentra drove me bonkers!
    for several months, i had been experiencing overheating engine. aircon wasn't as satisfying anymore.
    cars back then, had needle gauges and not idiot leds or lcds. abnormal engine temp was easy to see.
    i knew something was abnormal, because, when brand new, the temp needle would always be just below 1/2, regardless of time of day or traffic condition.
    mine was showing a temp needle already above the 1/2 mark. sometimes 3/4 of the way.
    the radiator's overflow cannister would get very hot, boil, and even dry up. i was losing radiator coolant.
    i kept inspecting the engine bay, and everything seemed to be functioning fine. no visible leaks in the radiator nor the cap. hoses were fine. malakas ang hangin ng aux fans.
    finally, an old-timer mechanic saw me peering at the engine bay. one look and a hand in the bay, and he concluded, "mahina na auxiliary fans mo."
    sabi ko, "malakas naman ang tapon ng hangin, a!"
    sabi niya, "mukhang malakas lang. kuha tayo ng brand new, at makikita mo kung gaano talaga dapat kalakas ng hangin niyan."
    he was right.
    i had the fans replaced, and the engine and aircon were as brand-new as can be.
    in some of today's cars, the temp needle had been replaced by leds or lcds, designed to catch your attention when the engine was already overheating and not before.
    idiot lights is right.
    Feb 2010
    #8687
    he was right.
    Doc, i had that same year sentra ss model, very cold calsonic aircon.
    Apr 2015
    #8688
    Wala ako sa Pinas kaya ito based lang sa sabi nung kapatid ko. On the day na nag-overheat yung kotse, nag blink red yung temp indicator 'tas yung aircon e wala lamig. Ayun lang, yun yung unang beses na nangyari, 'tas wala na, 'di na naandar talaga yung A/C fan 'tas yung ikot daw nung radiator fan e mabagal. Nadala pa naman nila yung kotse from Bulacan to Honda Kal para ipaayos 2 days after pero mga 30-min drive lang yun. Yung paghina buga ng aircon, feeling ko e baka nangyayari na dati pero mahirap tanyahin siguro kung yun lang ang basehan.
    5 years na rin yung akin, pero mga 90k na siguro odo nung sa akin, o lagpas.
    Dec 2014
    #8689
    Thanks!
    Na experience ko na yung sobrang hina ng buga ng aircon, pero ang problem pala is yung aircon filter ko, sobrang dumi na at parang inaamag na lagi ko kasi pina paalis sa PMS ko kasi bihira naman gamitin city.
    Nung pinalitan, parang bago na ulit aircon, kahit 1 lang lakas ng buga.
    So far, after 5 years ang nagiging problema pa lang ng city ko is,
    -Palit starter (pina palitan ko sa labas umabot 4k, sa casa 18k)
    -Yung back passenger window sa likod ng driver, delay yung power window, minsan tino topak ayaw bumaba.
    yan pa lang naman and sana wala na
    Sep 2018
    #8690
    Mga sir ano magandang size upgrade para 175/65 R15 ng honda city 2012?
    #8691
    Does it work that way? Baka more of pag nag red ilaw warning you pa lang na about to overheat ka na.
    Parang stupid naman na iilaw siya by the time na overheating na talaga. I’m thinking like the needle gradually going up, yan din yung time na iilaw siya.
    Hindi ako designer ng vehicle pero ang simple naman siguro nung concept na yung instruments are there to warn you ahead.
    Thanks!
    Ako yearly palit ng filter bro, parang ganun pala? Sign lang talaga na sira ng fan eh nag overheat ka? [emoji15]
    Okay pa starter ko (Thank God!)
    Rear windows ko din may delay, napindot mo na hindi agad gagana. Bihira kase i-open.
    #8692
    that's just it, sir.
    when the indicator lights up, i do not know where in the overheating curve, i am.
    my owner's manual isn't so helpful, either.
    it simply gives generic instructions geared towards minimizing engine damage...
    the issue is probably psychological. but it's a very effective psychological effect.
    Sep 2018
    #8693
    Mga sir ano magandang size upgrade para 175/65 R15 ng honda city? Kaya ba yung 195/60 sa stock rims?
    Oct 2013
    #8694
    Quote Originally Posted by alexatl19 View Post
    I used 185/60/R15 on my stock rims nung napudpud na yung 175/65/R15 ko.
    Oct 2003
    #8695
    If its blinking red, then temp is going up na. Pag steady red, thats the breaking point. But either way, best is to stop then let it cool down first.
    #8696
    one of my keyfob is no longer working. even after replacing the battery and cleaning the terminals.
    does anyone has any idea how much for a new fob? has anyone experienced the same?
    i'm assuming aside from the unit cost Honda might include a reprogramming fee to make it work on my car.
    #8697
    Quote Originally Posted by jojoR View Post
    Ano yun biglaan hindi na lang gumana? Yun ba ang daily keyfob mo?
    So far no issues saken, just replaced the batteries nung gamit ko daily and yung spare keyfob.
    #8698
    Yes, daily key fob ko for the last 2 years (dahil mas maganda yung keychain [emoji16]) yung spare gumagana pa. Napalitan ko na ng battery. Minsan umiilaw yung indicator kapag pinindot pero wala response. Hindi nabasa o nagbagsak yung keyfob
    Sent from my MI MAX using Tapatalk
    #8699
    Ahhh yun lang, casa na makakasagot sayo update mo na lang kami dito [emoji2]
    Apr 2015
    #8700
    Parang ngayon lang din ako nakabasa ng case na bigla na lang 'di nagana yung key fob. Ang mas nakakatakot e kapag 'di nagana ang push start >n<
    Kung ako, baka buksan ko pareho nung keyfob tas icompare ko kung baka may makita ako na magkaiba hehe.
2014 Honda City (Gen 4)
