Happened to me pero that time diskarga na yung battery, Nag series lang ako to start the car, nung papunta na sa battery shop ayun twice bumigat at umilaw yung EPS. Then nawala and nag normalize.
Iba case mo since okay pa naman pala battery [emoji848]
Hmmm thanks bro, hinayaan ko na lang at tolerable pa naman.
naalala ko, two weeks ago na diskarga pala battery ko nung may pinagawa ako sa detailing shop. 5 days kasi duon, baka nagpa tugtog ng stereo mga tao nila. yung voltmeter ko eh yung kinakabit lang sa cig lighter, how reliable ba yun? baka kasi ang na-read nun eh yung voltage ng alternator. sa mga battery shop may nag check ba dun ng health ng battery? thanks.
kahapon Sunday naman, hindi ko na experience na bumigat yung steering.
if the engine is running, the cigarette lighter voltage is the alternator's.
some battery shops offer free battery check.
A good read regarding EPS, I think applicable din sa City:
Electric Power Steering (EPS) Problems in the Honda Civic and Accord | AxleAddict
What to Do if the EPS Fails
If you do lose all power steering during driving, stay calm. Try not to turn. Pull over to a safe spot and turn off the engine. Wait at least one minute. The system should reset but may come on again until the issue is dealt with. Try to remember if the light came on while turning, while you were at a certain speed, etc. The Honda dealer will want to know.
Bro Tha_Mann,- what bro.drd was telling you is that the voltage across your car's electric circuit is 14.2V-14.7V and so that should be the same across your EPS motor... So, if the same issue comes out,- check your instantaneous voltage measurement. If it's good,- then you have to submit your EPS motor for an expert check.
If the car starts without any hiccup,- then your battery must still be good....
Anybody here using Carplay/Android Auto on their GM6? What unit are you using? Looking to get one installed.
may nakapag palit na ba sa inyo ng battery terminal? last July ayaw mag start ng car, kala ko na drain battery pero walang redondo or anything kaya check ko kaagad yung batt terminal, medyo maluwag kaya hinigpitan ko and true enough yun nga ang problem. then last Saturday nangyari ulit, maluwag na at sagad na yung turnilyo para higpitan pero buti nag start naman car. kaya plan ko na palitan na yung battery terminal, yung brass.
how much is the 2nd year PMS of your GM6?
from the estimate I’ve got, the big tickets are:
- pollen filter * 2.22k
- fuel filter * 4.88k
- ATF (3K HCF) * 1.99k
Tanong ko lang po kung anong led headlight yung maganda? Tsaka po yung maliwanag? Honda city 2012
