if you are in metro manila,
for pre-used, try the cathay centers in evangelista makati and in banawe QC.
brand new should be about 3K... peruse the online sellers, po.
since that model is locally assembled, it should not be too difficult to look for an affordable replacement part.
if most of the parts are with you, and you are impoverished, you can try glueing the pieces back together. use liberally the glue, so's the finished product is waterproof.
Guys me nakaexperience na ba sanyo na nagka rust ung any metal parts ng city nyo? Ung sakin kasi sa pinto sa me driver side. Dati ung gas cap metal cover nagkaroon sa hinges nirepair naman nila ng free, now eto na naman. Any inputs.. thanks
Sent from my SM-G930F using Tapatalk
For GM6 anong year nilabas yung smoked headlights? (Yung walang DRL ha)
Just checked kanina both lights not working
IIRC it will lit pag engaged ang brakes? (Naka apak ka)
Naka ilaw ba yan pag on ang park lights?
Basta ayaw umilaw both sides.
(Car not mine BTW ctto)
i don't honda, but
both lights affected at the same time?
i'd check the rear light switch and the fuse.
but, as unlikely as it may, i'd check the bulbs first. they're the easiest to check, kasi.
good luck.
* cnc
Parang yung mga bagong city lang ata from 2018?
not sure kasi dun sa article na nabasa ko wala namang city sa list or maybe US article kaya hindi na nila sinaba city.
kahapon while stuck in traffic, biglang nag blink yung temp light ko. nasa gitna pa naman ako ng road. ginawa ko eh off ko muna yung aircon ko, after a few minutes eh tumigil. daily ko naman check yung water level sa reservoir saka sa radiator, hindi naman nag babawas. pag uwi ko sa house, napansin ko na hindi umiikot yung auxiliary fan ko, nung pinitik ko, saka lang umikot. buti yung radiator fan eh umiikot naman yun lang parang na o-overworked na.
ano kaya need check muna? may fuse ba ito? or palit fan na? alam ko magkasama yung rad & aux fan yata pag pinalitan.
Most likely one or two of the fan motors are busted. Have it checked from a nearby shop that specializes on small motors. It happened on our old 2009 City before and I had it changed. The stock fan motors used by Honda is made by Denso, same as most other Japanese cars.
Don’t bring it to the casa as they will charge you for the whole radiator and auxiliary fan motor assembly.
Changed full set of tires last weekend pero d nagawa camber/alignment cos the tie rod, rack end and stab link needs changing. Can anyone suggest/reco a good shop where to buy and any specific brand? TIA.
