Results 1 to 10 of 177
February 19th, 2011 12:40 AM #1
*admin - If this thread qualifies to be sticky, I humbly request it to be so.
As reaction to the issue of having some sort of auto lock, speed sensing or not and my own desire to have it, I formed a plan to do a mod so that when first stepping on the brakes, FoFi will lock itself. Stepping again will have no effect unless it is unlocked first.
Here are the initial steps towards that goal. You might have your own plans for this vicinity of the FoFi in terms of audio and such so I thought it might be useful for other things as well
February 19th, 2011 12:45 AM #3
Nako as much as I want some form of auto lock, I just don't have the guts and more importantly the expertise to do what you are doing so I will just stick to the good old habit of locking!
February 19th, 2011 03:05 AM #4
Thanks to Sir Tidus, I first saw this:
[ame="http://www.youtube.com/watch?v=GDnHL47kXg4"]YouTube - Ford fiesta mk7 **Secret menu**[/ame]
Researching further, I found this:
http://www.fordownersclub.com/forums...howtopic=13609
" To get to it, do the following:
1) Put key in ignition (do not turn)
2) Hold the button on the rev side and after around 3 seconds turn the key two clicks (don't start engine)
3)On the screen it will say "Test" and you can cycle through various things by pressing the button.
Some things include: gauge test, LED test, digital speedo etc. "
February 19th, 2011 03:10 AM #5
Opening driver side door panel. I assume other doors will be easier.
February 19th, 2011 03:19 AM #6
How to remove your fuel port cover so that you can glue it back avoiding it accidentally falling off:
Thanks to Izeman_X again for revealing his discovery so that we may be warned.
February 19th, 2011 03:29 AM #8
To use or just see "secret compartment" between radio and A/C controls, use a knife to gently pry it open at the center.
To put it back, you must separate the metal clip from the peg, return it into the hole in the dash, then push the door back to normal.
- Jan 2011
- 382
February 19th, 2011 08:32 AM #9ang galing... WOW...Ang naaaalala ko ikaw din yung naglagay ng blue lights sa headlights...Very nice work
Probably looks like a Coke sakto. Yes, where did you buy it?
Fire Extinguisher for Car: what brand and type...
