Results 1 to 10 of 177
February 19th, 2011 12:40 AM #1
*admin - If this thread qualifies to be sticky, I humbly request it to be so.
As reaction to the issue of having some sort of auto lock, speed sensing or not and my own desire to have it, I formed a plan to do a mod so that when first stepping on the brakes, FoFi will lock itself. Stepping again will have no effect unless it is unlocked first.
Here are the initial steps towards that goal. You might have your own plans for this vicinity of the FoFi in terms of audio and such so I thought it might be useful for other things as well
February 19th, 2011 12:45 AM #3
Nako as much as I want some form of auto lock, I just don't have the guts and more importantly the expertise to do what you are doing so I will just stick to the good old habit of locking!
February 19th, 2011 03:05 AM #4
Thanks to Sir Tidus, I first saw this:
[ame="http://www.youtube.com/watch?v=GDnHL47kXg4"]YouTube - Ford fiesta mk7 **Secret menu**[/ame]
Researching further, I found this:
http://www.fordownersclub.com/forums...howtopic=13609
" To get to it, do the following:
1) Put key in ignition (do not turn)
2) Hold the button on the rev side and after around 3 seconds turn the key two clicks (don't start engine)
3)On the screen it will say "Test" and you can cycle through various things by pressing the button.
Some things include: gauge test, LED test, digital speedo etc. "
February 19th, 2011 03:10 AM #5
Opening driver side door panel. I assume other doors will be easier.
February 19th, 2011 03:19 AM #6
How to remove your fuel port cover so that you can glue it back avoiding it accidentally falling off:
Thanks to Izeman_X again for revealing his discovery so that we may be warned.
June 27th, 2011 07:13 PM #7
Hi sirs, may prob ata yung wipers ko.. Minsan sumasablay sya in wiping my windshield. It's making this "trrrgggg" sound/motion esp pag mabilis (di ko mashado maexplain pero i hope magets nyo). Has anyone experienced this on your fofi? Ano po kaya pede gawin? Thanks
June 28th, 2011 06:53 AM #8
June 28th, 2011 11:13 PM #9
yun din actually naisip ko nung first time. pero yung mga sumunod na instances, im sure malinis naman yung windshield and wiper. actually sa simula ok naman. pero pag tumagal, lalo na pagmalakas na yung ulan, bigla na lang nagkaganon. My friend who owns a ford focus told me na sakit daw ng ford yun kasi ganun din daw yung kanya.
July 26th, 2011 01:31 AM #10
I have been noticing that the plastic trims on the door frames are magnets to scuffing. The scuff plates we buy as accessories are nice looking but do not protect these vulnerable spots. I am using faux carbon fiber vinyl stickers to add some looks at the same time protect the trims.
You can see the scuffs in mine
These trims along with the door pillar trims come off easily. (Use some firm force with only your hands)
Before & after view
The front door trims
Closer look
View with them installed
Thread was made nung 2018 pa po sir.
