Page 235 of 254 FirstFirst ... 135185225231232233234235236237238239245 ... LastLast
Results 4,681 to 4,700 of 7777
    ^ nabasa ko nga iyong sua like symptoms ng everest nyo a few weeks back bro. medyo scary din. Hope everything is ok uli
    ok naman sir, since pag nilagay mo sya from drive to park saka lang tataas ang rpm. beyond that, control naman yung sitwasyon. First time ko din kasi ma-experience yung ganyan kaya kinabahan din nung una.
    Quote Originally Posted by alrorskyz View Post
    Anong sabi sa casa at anong ginawa nila?
    Mine is 2017 also kaya worried din ako
    Sent from my SM-A720F using Tapatalk
    Hindi ko na rin dinala sa casa sir, after kasi na magamit si Eve ng several times nawala na. This time, plan ko tignan mabuti yung gas pedal kung may dapat bang lagyan ng lubricant or adjust something para bumalik sa normal position yung pedal after release sa pagkakaapak.
    Quote Originally Posted by maxpedition View Post
    Dont worry daw small lang yung chances tamaan everest natin ayon sa expert [emoji12][emoji12]
    Nagkaroon ng worry sir, kumabog din ang dibdib. pero after knowing yung possible na problema unti-unti na rin bumalik yung confidence.
    occurrence is still much lesser than alleged SUA incidents...
    I think may problema talaga sa accelerator or sa adjustment or sa spring, plus nagkataon din na malamig ang panahon tapos hindi talaga nagamit si Eve ng more than a month.
    Jun 2010
    ano na kaya nangyari sa unit ni sir suysuy?
    Sent from my RNE-L22 using Tapatalk
    Mar 2007
    Quote Originally Posted by gomez_ea2 View Post
    Tuesday pa diagnosis. Backlog sila dahil sa holiday. Pinasilip ko na sa ibaba. Walang nakalas.
    Sent from my SM-A605G using Tapatalk
    Jun 2010
    Quote Originally Posted by suysuy View Post
    tagal ng suspense ah, anong year model pala yung unit mo sir?
    Mar 2007
    We had it since oct. 2015. Not sure if it's considered as 2016 model. So it's 2015. We are one of the few first customers who bought a titanium premium 4x4 model still priced at 1.99m
    I think its 2016 model sir, release ng 2015.
    (mukhang malapit na rin matapos ang warranty period sir)
    Mar 2007
    Tuesday pa diagnosis. Huhu. Try ko tumawag ulit bukas. Napadaan ako kanina sa dealer naitow na sa loob yung unit. Nawala na sa parking space
    Sep 2014
    parang malakas ang kutob ko battery yan problema ng everest nya. di pa kaya napalitan?
    kung powertrain yan, baka fuel related yan. I used to have that wrench indicator sa Ford explorer dati, fuel rail sensor, oxygen sensor or maybe even throttle sensor. kasi pag nag fail talaga ang computer ng ford sa computation netong mga sensors nato, nagkakaganyan yun wrench. yan ang hirap sa Ford talaga sa dami ng electronics na nakakabit, nagiging complicated.
    did you bother to even remove the battery terminals para ma reset ang buong computer? one time I connected my OBD Blutooth Scanner sa Wildtrak, after driving for awhile, akalain mo nawalan ng touch yun Iphone 6S ko, nag reinstall pa tuloy ako ng iphone. ganun katinde computer ng Ford lol
    Mar 2007
    Battery is new. Replaced it 6 months ago. Yup i already removed the battery after it happened. Nawala lang yung wrench indicator but the car still wont move.
    Nov 2017
    Mukhang mechanical na yan hopefully cover pa ng warranty. Give us update sir
    Jun 2010
    anong balita sir suysuy?
    Sir, try to back read...ops, na qoute ko na pala...
    [emoji16]✌️
    Jun 2010
    [emoji16][emoji111]️
    nabasa ko yan sir, di ko lang naalala na tuesday this week.. thought nung tuesday na check.. di ko na kasi tanda kelan ko last na tanong sa kanya
    Aug 2018
    dont worry understandable naman if me issue ganyan medyo alarming din yung nangyari ke sir suysuy
    Oct 2003
    How can we make the torque be available earlier? And probably make the gearing shorter? Chip tuning?
    Aug 2018
    Kamusta na kaya yung eve ni sir suysuy [emoji4][emoji4]
    Mar 2007
    Quote Originally Posted by FordGuySRA View Post
    Wala pa update. Ill post updates here once avaiable hehe.
    Mar 2007
    After a week wala pa official findings. Contact pa raw nila planta to make sure tama kanilang diagnosis.
    Nov 2017
    Aray ko [emoji23][emoji23][emoji23]
Ford Everest 2015
