Page 95 of 359 FirstFirst ... 4585919293949596979899105145195 ... LastLast
Results 1,881 to 1,900 of 7178
    Dec 2012
    #1881
    Sir, hindi pa po ako nakaka kuha. siguro by this mid Jan or early... I'm planning to get a MT... For me its more fun to drive...
    Cabanatuan Nueva Ecija po ako eh. So baka mag pampangga or Cabanatuan dealer ako... idk if they have an AT ranger...
    hirap mag choose ng color...
    #1882
    Quote Originally Posted by nicenz View Post
    Ah ok. I agree with you..mas masarap tlaga ang feel ng manual dahil you feel the connection between man and machine..
    kaso nga lang kung everyday na magiging EDSA ang ruta mo..isipin ko pa lang nkakapagod na..and I've been using a/t for several years na.
    Goodluck sa color of choice mo, pero kahit anong mapili mo pogi pa rin yan Ranger yan e.
    Dec 2010
    #1883
    Quote Originally Posted by kingston99 View Post
    Thanks sa info sir, matanong lng, wala bang parang chime sound pag mag insert ka ng key? at pag di ka naka seatbelt?
    Wala pong chime sir.
    Sep 2012
    #1884
    Sir pano po ba e reset yung li/100km?
    kung naka display na yung average li/100km, long press (press and hold) mo lang yung set/reset botton hanggang mag 0 yung reading.
    Pero as per experience ni sir zamoco, no need naman na pala to reset.
    Btw, 2 types yung fuel consumption reading ha, yung average FC at instant FC. Malalaman mo na instant fc yung nakadisplay if instanteneousIy changing Yung reading.
    #1885
    Quote Originally Posted by JX290 View Post
    Yes gumagana po, above 40 kph if I am not mistaken. By just pressing the button and then the + and - buttons.
    Intrigued by that sa MT. Pano yun, hahabulin nung Ranger yung speed while sticking to a single gear?
    Dec 2010
    #1886
    The answer is yes.
    #1887
    It maintains your current speed when the cruise control is turned on. The +/- will adjust your speed incrementally by 1 or 2 km/h. If your rpm is too low or too high for that gear then it's time for u to change gear. Once u change gear or brake, the cruise control switches off.
    Dec 2012
    #1888
    Guys, Im about to buy a ranger this month, though still have a few questions....
    How come the engine of the New Ranger doesn't have a VNT(Variable Nozzle Turbo)?
    And the Mazda BT-50 does have one? what is the difference?
    #1889
    Quote Originally Posted by A-OK View Post
    Was just comparing it to the cruise control on an auto tranny. Since it's an auto, when "resuming" from a lower speed, it will do the necessary gear shifts to attain whatever speed you've programmed in. With the manual tranny though, it's just more of a speed lock.
    Aug 2008
    #1890
    Both the Ranger and Bt50 have Variable Geometry Turbo. They share the same engine. VNT is another name for VGT but are actually the same.
    Jun 2007
    #1891
    its becuase it has a vgt rather than having vnt... but still they have turbos unlike the past ranger with mechanical..both turbos are variable which stands for the vnt (variable nozzle turbo) and vgt (variable geometric turbo.... the mazda and ford both share the same engines
    Nov 2012
    #1892
    Quote Originally Posted by taraki17a View Post
    Thanks sa mga reply sir.
    Tama po si sir zamoco, bumaba na FC namin. 9.6L/100kms(city)/(11.3L/100kms (highway) na. 350 kms na natakbo namin.
    Smooth pala ang ranger kahit nasa 130kmh. Lalo na pag nasa asphalt. Di mo mahahalata na mabilis na pala takbo ninyo.
    Well, yun ang experience ko. Nasa backseat ako palagi si erpats kasi nagmamaneho.
    So far, yung concern lang namin ay yung pag park sa malls at parang nasisilawan yung mga sasakyan sa ibang lane kahit off ang fog lamps at naka low beam kami.
    Dec 2012
    #1893
    Quote Originally Posted by lytspid View Post
    How come the ranger does not have these features: ABS | EBD | BA | DSC | TCS | HSA | HDC ??? But the Mazda BT-50 4x2 does have it? I would have been better if they have those features... darn
    #1894
    Well, this could be Ford and Mazda's way of trying not to eat into each other's market 100%, by not going completely head to head.
    Dec 2010
    #1895
    Sir, fyi, meron, ABS at EBD ang 4x2 ranger, pero yung ibang features wala.
    Aug 2012
    #1896
    I believed that the Ranger does have some of the features you listed like the ABS/EBD/BA for the XLT variant that is. The WILDTRAK I think have all the features listed.
    Dec 2008
    #1897
    and more expensive mazdaBT-50 4x2.
    Dec 2012
    #1898
    Quote Originally Posted by Aleman View Post
    I know it has ABS with EBD but what is BA?
    Do you guys recommend 4x2 XLT MT?
    Nov 2006
    #1899
    I would recommend it but if you have a bigger budget and can wait I'd go for the 2.2 Wildtrak which will come this year but indefinite pa when.
    #1900
    Ganun talaga limitation ng MT. Though it can still resume speed but to lesser extent or limited speed range for a certain gear. Say +/-10kph. Bec I opted for MT, I have to bear with it. Just describing how cruise control works in MT. AT has better advantage in cruise control. I guess AT fits your requirement.
2012 Ford Ranger
