Page 117 of 359 FirstFirst ... 1767107113114115116117118119120121127167217 ... LastLast
Results 2,321 to 2,340 of 7178
    Dec 2010
    #2321
    Quote Originally Posted by Tj_abs View Post
    Mga bossing meron na ba recall ranger natin? My napapansin ba kayo tunog when shifting /automatic? Parang my bato na tumama sa ilalim? And last when i turn off the engine my tunog na parang disc player sound?
    Yung parang disc player na tunog ay yung motor ng vgt na nagcontrol ng vanes. e vgt kasi ang ranger, normal lang yun.
    #2322
    Quote Originally Posted by JX290 View Post
    No, it's not normal for a vgt to have that sound. Vgt din naman ang eve at montero pero wala namang ganiang sound.
    Dec 2010
    #2323
    How true is this? Yung 2.2 ito na 4x4 not the wildtrak.
    (quote from Paul Tan's automotive news.
    The Ranger 2.2 XL Manual is also a high-riding double-cab 4X4 truck like its XLT and Wildtrak brethren (water-wading capability of 800 mm, ground clearance of 200 mm), but its 2.2 litre Duratorq TDCi makes less power and torque – 125 PS/320 Nm versus the XLT’s 150 PS/375 Nm. It may be 55 Nm down on the XLT, but max torque is made at a very low 1,700 rpm, which is 800 rpm lower than the stronger engine.
    Another difference is that the detuned engine in the XL uses a fixed vane turbocharger, as opposed to the variable geometry turbocharger in the XLT. No auto option available for the XL, just a six-speed manual, the same MT82 gearbox offered on the XLT.
    unquote)
    Dec 2010
    #2324
    Quote Originally Posted by beni23 View Post
    Electronic vgt ba ang eve at montero nyo sir? napansin nyo ba ang maliit na bagay na nakakabit sa turbo ng ranger na merong linkage? thats a small motor, yun yung tumutunog sir, pinoposition nya yung vanes sa tamang pwesto when you shut off engine.
    #2325
    Yes thats it. The montero VGT has that also. Its noticeable after turning off the engine. The vanes will kinda re-set after several seconds..
    #2326
    More pics of the test drive:
    Aug 2011
    #2327
    Quote Originally Posted by Djerms View Post
    Parang spring ba. I hear something din sa manual Ranger ko coming from cold start in first gear
    Yes sir. I dont know kung normal ba ito or hindi? Mine is automatic. Dont know kung my tunog spring din sa manual when shifting.
    Aug 2011
    #2328
    Thanks for the input sir. But aside sa parang disc napansin ko din na when u turn off the engine malakas ung vibration nya to think na bago pa ung mga engine at tranission support ng pick up ko. Dont know kung normal din yun?
    #2329
    I felt a significant reduction on the engine vibration and turn off kick aftr using euro 3/4 fuel. Not sure if its connected. Try seaoil or unioil
    Aug 2008
    #2330
    AFAIK, that sound comes from the common rail, i think from the pump. Even the non vgt montero has that sound after turning off the engine. You cannot hear it in some other cars because it is suppressed especially when the hood is closed. My bros sportage does not seem to have this sound when the hood is closed but when it is open, you can clearly hear it.
    #2331
    Quote Originally Posted by rac98 View Post
    Yes yes. Sorry for the wrong info (and thanks for clarifying). Just realized its not on the turbo side so its not the vanes. But yeah the sound is normal...
    Sep 2012
    #2332
    so where is that 'disc' sound coming from? from the vgt homing its vanes or common rail releasing fuel pressure?
    *tj abs, do you cool down your engine before shutting it off? baka off mo agad agad kaya ma vibrate?
    Nov 2011
    #2333
    Ang ganda siguro pag naka Black Rhino sidewinder Saan ba nakakabili nito? meron bang mas mura kesa sa concept one wheels o mura na un benta nila? 95k kasi with nitto tires daw. 20"
    thanks
    #2334
    My ranger just turned 1000kms older. Satisfied with Ford Libis' pms. Pretty much organized and customer oriented. Might stick to this branch for future schedules. FYI.
    Dec 2012
    #2335
    Hi guys, saan maganda magpalagay ng back up sensor? And other accessories na mura? I am soo proud owner of the new ranger. Napaka sulit. Pero medyo hndi p ko sanay sa transmission nya. Ung first gear bigla pumipitik minsan na matayan pa ko twice ng pa ahon ako sa gutter hahaung 1.5k na pinang gas ko avarage ng 500+kms ang tatakbuhin sulit na ba yun?
    #2336
    Quote Originally Posted by clairenceh View Post
    thanks
    Sir, try mo sa evangelista along makati. Lots of stores there selling mags n wheels. May 85k sila promo for 20s.
    Hope this might help :-)
    #2337
    Sir djerms, what work/job did they do po sa unit mo on your 1000kms PMS?
    #2338
    Quote Originally Posted by nicenz View Post
    Sir nicenz try mo po sa banawe mag canvass, I would suggest you make a list of all the accessories you would like to install sa unit mo then give it to several stores there. Parang package price na kamo, kumbaga dun mo na kukunin sa kanila lahat ng NASA list mo if they can give you good price. E-bargain mo Lang ng todo hehe....
    About your fuel consumption, magbabago pa yan defending on your driving skills. Computer will asses the way you drive both in city and hi-ways...
    Hope this may help po :-)
    Dec 2012
    #2339
    Quote Originally Posted by zamoco_08 View Post
    Thank you sir.
    Aug 2011
    #2340
    Sir try nyo sa road fit at calamba st banawae. Certified installer sila nf ford greenhills and ford edsa. Look for sir paul. Tell him refer ka ni tj.
2012 Ford Ranger
