Malamang normal yan. My L200 used to do thay too all the time hehehe.
Sent from my GT-I9082 using Tapatalk 2
Hope this helps... after browsing i found this on other forums about :
"the drivetrain has a distinct knock when releasing the clutch"
"I drive one of the manual 2.2 Fords at work and had the same problem with the knock on the gearbox.. Originally it was said its the links on the gearstick that causes the gear to not fully engage until you apply some torque then it pops in. Then it was a story about the thrust bearing. Eventually the real thing came out and changing drive style fixed it. The clutch has some mechanism to prevent stalling so make sure you fully, as in take your foot of the clutch completely before applying gas. This is a excellent feature once you get used to it." - WillysCJ
"Your Clutch issue is not a clutch issue but a feature. Release the throttle when changing gears. It matches rpm to ensure smooth shift. If you also give throttle engine speed does not match and it jerks and knocks."
Thanks sa mga nagreply, at least may peace of mind na ko when I go to the casa tomorrow.
Sabi ng ahente ko hindi daw rustproofed ang under ng ranger. Ung sainyo ba? At hindi pa ko nkkpg undercoat.
Bobo yang ahente mo sir. Pardon for the language. Binebentahan ka lag niyan ng undercoat. If you really want one just get from outside. Baboy din gumawa ng undercoat sa casa. Uulitin ko. Factory rustproofed ang lahat ng mga sasakyan. Pwede sir pakisabi sa ahente na yan bago siya magsalita wag aanga anga. Hehe.
Undercoat sometimes do more harm than good by retaining moisure. Ive had undercoated cars and had some with none. Walang difference hehe.
Mga sir, may alam pa po kayo ng merong fender flares for T6 sa Banawe aside sa Goldcars ? Wala pa daw kasi yung stock nila....
Sent from my HTC Butterfly using Tapatalk 4
Saw a Metropolitan Grey Wildtrak along West Ave. yesterday. Inooffer na ba ng Ford PH yun color na yun? Looks really good too
To wildtrak owners how do you protect the tip of the tailgate? the tip (lip) is exposed not like the other units that has a cap on it. Everytime I load stuff from the farm (medyo mabigat eh) workers get to hit that portion
