Results 31 to 40 of 59
January 27th, 2012 11:32 AM #31
STP oil treatment is the best product out there, (providing you use it correctly) It is not intended to be used for oil burning engines as a quick fix or any other quick fix ideas. You put a bottle of it in your engine every time you change your oil.
STP is still average $2.50 - $3.00 a bottle, depending on where you get it and it does the same thing that all these higher priced additives claim to do. I use it, and have been for over 20 years. It contains detergents which enhances the oil's viscosity and keeps the engine clean and sludge free, and when used regularly over a period of time, it will actually "bake" into the metal inside the engine leaving a protective film to reduce wear. It is ok to use it in a new car after the break in period has passed, that will be a sure guarantee that your engine will have a long life providing you change oil regularly. I have worked on engines that has used it and personally seen the positive effects it has. I have not seen anything that outdoes it, and besides, take a moment and think about how long that product has been on the market......................... a long time.
January 27th, 2012 11:35 AM #32
why can't people just be satisfied with MOTOR OIL?
motor oil na recommended ng car manufacturer
yun lang
baket kailangan pa ng whatever treatment treatment?
January 27th, 2012 11:40 AM #33
January 27th, 2012 12:00 PM #34
our 2NZ-FE vios uses STP every oil changed up to now 137,870km on odometer, engine power still the same, our corolla 2E with 494,160 km uses STP since 1995 till now 2 times overhaul conrod bearing, main bearing, camshaft ,crankshaft, rocker arm, engine block, etc. are still original 1995, only piston ring replaced.
January 27th, 2012 12:53 PM #35
top one... ive tried that no changes at all... fc, temp. etc... mura lang pero sayang pa din ang pera....
- Nov 2009
- 1,756
January 27th, 2012 02:21 PM #36
- Jun 2008
- 1,741
January 27th, 2012 03:01 PM #37My own take:
Don't use engine (oil) treatment sa brand new or newly overhauled engine. After break-in or about 15k odometer reading pwede na.
I regularly used Pertua engine treatment from 1988 to 2003 in my old 1979 12R toyota corona wagon. The engine was running very smooth more than the nissan sentra of my neighbor. I scrapped the car not because of the bad engine but due to body defects.
January 27th, 2012 08:20 PM #39
January 28th, 2012 03:45 AM #40
inside of STP oil treatment 2010
ZDDP (ZINC) is the one who makes the engine last forever protects against engine wear.
https://www.autoindustriya.com/auto-industry-news/nissan-confirms-van-partnership-with-mitsubishi-fo...
Mitsubishi Philippines
