Quote Originally Posted by EE100shiro View Post
STP oil treatment is the best product out there, (providing you use it correctly) It is not intended to be used for oil burning engines as a quick fix or any other quick fix ideas. You put a bottle of it in your engine every time you change your oil.
STP is still average $2.50 - $3.00 a bottle, depending on where you get it and it does the same thing that all these higher priced additives claim to do. I use it, and have been for over 20 years. It contains detergents which enhances the oil's viscosity and keeps the engine clean and sludge free, and when used regularly over a period of time, it will actually "bake" into the metal inside the engine leaving a protective film to reduce wear. It is ok to use it in a new car after the break in period has passed, that will be a sure guarantee that your engine will have a long life providing you change oil regularly. I have worked on engines that has used it and personally seen the positive effects it has. I have not seen anything that outdoes it, and besides, take a moment and think about how long that product has been on the market......................... a long time.
our mechanics use STP pang alis blow-by
old engines na kailangan na palitan ng piston ring... STP is a remedy... just to get the unit sold
kaysa gagastos pa kami palit piston ring
