Results 41 to 50 of 59
January 28th, 2012 03:51 AM #41
Well the 2004 STP oil treatment have a ZDDP Zinc of 1,959. But hey you can find a STP with 2004 manufactured in any auto supplies.
STP 2004
Calcium 1371 ppm
Phosphorus 1814
Zinc 1959
100C viscosity 108 cSt.
January 28th, 2012 04:41 AM #42
Plenty of it in the states at a place called big lots, I just had some analized but it came back kinda low, it actually should be around 3900ppm zinc for the Red STP 4cly oil treatment. I did not mix up the sample and took the oil from the top so I think it settle out since it has been sitting in a warehouse for about 8 years. But it's still perfectly fine, I'm going to get anouther sample run. It should be adding around 400ppm zinc and phos to 5 quarts of oils. The STP oil treatment in the blue bottle has half as much as the red due to EPA rules on ZDDP content and it's also much thicker.
STP - Bob Is The Oil Guy
I use it in my cars to boost up my oil, and get a little bump in fuel economy with it. I only use a additive is I know exactly what is in it. I posted in the oil filter thread about where to do engine oil testing. Maybe someone can get the stuff tested to see if it's worth the money. It's pretty much why I have not said anything good nor bad about it. Have no ideal what's in it.
- Nov 2009
- 1,756
January 28th, 2012 03:34 PM #43
February 2nd, 2012 11:47 AM #45
http://www.top1oil.com/pds/10108_PDS.pdf
Wonder just how much moly this stuff has in it? What's the cost of this stuff anyways.
February 2nd, 2012 04:29 PM #48
So far, na try ko pa lang na additive is Liquiy moly... the MoS2 and the ceratec...
The MoS2 which has lots of moly in it did improve my fuel consumption from 4-5 to 5-6 on a 6 cylinder gasoline engine.
while the ceratec which has lots of boron performed just the same from 10-11 to 11-12 on a 4 cylinder diesel engine.
i think before you use any additive it must have proper documentation and technical specs in the first place so you can benchmark it...
February 2nd, 2012 04:44 PM #49
- Nov 2011
- 36
February 27th, 2012 04:30 AM #50Anu pu ba ung engine (fuel) treatment sorry kinda new in this section just got my 1st car about a month ago.
Buy the one with the active safety features ... if it saves you once or twice from an incident then...
All New Toyota Corolla Cross
