Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 59
    Oct 2011
    Ang mahal na nga ng fully synthetic oil. Gagastos pa dyan sa treatment na questionable ang benefit and performance sa engine.
    yung iba nga dyan tumaas lang ng konte ang presyo ng fuel galit na galit sa mga oil companies
    pero willing gumastos ng hundreds of pesos para sa fuel additive na di maramdaman ang benefit
    hahaha
    Jan 2011
    Mukhang bihira gumagamit niyan sir, sakin na try ko na X1-R engine oil treatment, ok yung result
    Dec 2009
    hindi kalokohan ang engine oil additive o fuel additive,, napapa sama lang dahil majority of these products are not really able to deliver their claims. So the mindset of those who were unfortunate to buy those non performing additives will be biased..
    If you do your research and homework first, your money will be well spent
    MOLYBDENUM BASED ADDITIVES - search nyo sa net regarding molybdenum additives para ma enlighten ang mga nasa dilim pa!!
    *Moly has a very low coefficient of friction even in the higher heat ranges to 750 degrees F
    *Major oil companies and most large industries are depending on oils and greases fortified with Moly to extend the service life and reduce maintenance on aircraft, trucks, compressors, tractors, ships and automobiles. Properly used it can double the operating life of equipment and reduce maintenance as much as 60%. Another small plus for Moly in these days of fuel prices, is that an engine treated with Moly usually obtains 10% to 25% better fuel mileage. Moly reduces friction in an engine up to 60%.
    *It possesses the properties of being able to withstand extremely high load capacities (400,000 psi). It is chemically stable, has a very low coefficient of friction (0.05 to 0.09 in powder form) and has thermo-stability over 2,000°F. All of these properties are essential to reduce metal to metal contact and thereby reduce friction, heat, and wear
    BORON NITRIDE OR CERAMIC BASED ADDITIVES- these additives are among the latest if not the best performing additives that has scientific data and background to back its claims...
    *Temperature stability of the
    ceramic particles : To +1,200 °C
    *A ceramic-metal layer formed during action of an additive makes for enhances tightness of rings and a tube
    *Durability of ceramic-metal layer corresponds to coaled surfaces and in under guarantee for distance of 70 000km
    * Excellent Lubricating Properties due to low Coefficient of Friction at 0.15 to 0.70
    Good Chemical Inertness
    Electrical Insulator
    Thermal Conductor (result: better heat dissipation)
    High Temperature Stability, 1000o C in Air, 1400o C in Vacuum and 1800o C in Inert gas
    Low Thermal Expansion
    Low Dielectric Constant
    High Load bearing properties
    Non-Wetting: hBN is not wetted by Glasses, Salts and (most) metals, therefore it provides strong resistance to chemical attack Easy Machineability (in hot pressed state). Complex shapes can be machined from hot pressed structure.
    one treatment will last you around 40,000kms to 70,000 kms... boron nitride is virtually indestructible once it binds into your engine metal parts
    yeah whatever
    Dec 2010
    yeah whatever
    good evening....
    mga frendship try ninyo po ang AERO WONDER LUBE (ENGINE TREATMENT) maganda po siya dami po siya benifits sa sasakyan.. subok na subok na po itong product na ito... Thanks po Godbless...
    ano uli?
    duralube?
    sige bigyan mo ako ng sample
    after 6 months malaman ko kung may benefit... then i pay
    Jun 2011
    ano uli?
    duralube?
    maganda nga daw po yun... sbi nung friend ko... nabutas daw ang water hose nya at nauubos ang tubig then he was still able to run his fx from makati to fairview with a.c. loaded with passengers with no changes in temperature....
    i also put one on my tranny mas magaang po tumakbo ang car ko...
    Quote Originally Posted by glenn manikis
    Sige, let's try it on your car, alisan natin tubig and engine oil tapos lagyan lang natin ng duralube then gamitin natin tutal yun naman ang pinapakita sa infomercial nila eh.
    sige nga bigyan ako ng sample
    after 6 months babayaran ko pag na-convince ako
Top 1 Engine Treatment
