Page 41 of 52 FirstFirst ... 3137383940414243444551 ... LastLast
Results 801 to 820 of 1023
    #801
    Add ko po pala...meron pa po kayong promo dun sa change oil? If so, anong viscosity recommended para sa ride ko? 1.3l QG13DE makina nya eh.
    Jun 2006
    #802
    just saw the last stand. lakas ng ads ng royal purple sa movie
    Sep 2011
    #803
    Hello Sir,
    For L300 diesel ano pong oil pwede? Old car na. Regular use Shell oil. And for gear oil what do your recommend? Tks.
  4. #804
    Quote Originally Posted by userfriendly View Post
    Same with "Real Steel". He he he!
    #805
    Quote Originally Posted by nowheeldrive View Post
    Sir Speedyfix, gandang gabi po. Anong ATF po ang recommended nyo for 04' Sentra GX A/T? At ilang liters/quarts po ang kelangan? Baka drop by ako sa shop nyo po next saturday. thanks.
    For a quick drain and replace, around 2-3L tops.
    Mar 2013
    #806
    Hi Sir SpeedyFix,
    Ask ko lang paso ba sa 2700 promo mo yung change oil sa Honda civic 2003? Saka anong oil filter ginagamit nyo? Also kung anong viscosity usually nilalagay nyo pag sa ganung sasakyan?
    I might need to flush the engine oil also dahil ngayon lang ako magttry ng royal purple. Can you PM me for quotations?
    Thanks!
    Oct 2011
    #807
    Sir speedyfix, pag RP ginamit plus ung filter niyo, kaya ba every 10k or 1 yr OCI for a D4-D engine?
    Nov 2003
    #808
    wutangclan_79 for the mirage 5w30, for the sportivo 15w40.
    gaellazar yup back in stock na.
    monty_GTV if you want one of our dealers to ship it, Al of HP racing is the best bet. the guy on sulit is not one of our dealers.
    nowheeldrive 2-3 quarts lang for the atf. sentra falls into promo also
    jdjoeydean for l300 the 15w40 and maxgear. but might be quite expensive compared to the mineral oil you're used to
    yojstamaria yes pasok sa promo. we'll normally use a 10w40 or 10w30 for your car depending on milage. we use purolator. for the flush we'll use liquimoly.
    retz, pwede naman to go up to 10k for the newer diesel engines.
    Oct 2011
    #809
    k, thanks sir speedyfix.
    Nov 2003
    #810
    anytime!
    Feb 2013
    #811
    Paps, sa innova VVTi 2008 model, ano po Royal Purple ang gamit, ilang liters and also how much per liter.
    Thanks.
    Pwede rin ba provincial orders sa inyo?
    Nov 2003
    #812
    you can use the 10w30. you'll need 6 quarts. try ordering from PhilShopping.com | Online Shopping Philippines | Online Shopping
    May 2005
    #813
    Quote Originally Posted by siopaonatoasted View Post
    Thanks.
    Total capacity is 5.4 or 5.7 liters (with oil filter already). I will check the manual later.
    To avoid overfilling, Its better to put in 5 liters first and *slowly* top up until full. Use the dipstick as guide/reference. It will take less than 1 liter from the "L" to "F" mark
    Nov 2003
    #814
    good advice. it's easier to add oil than it is to drain it again.
    Oct 2011
    #815
    sir speedyfix, what if na overfill drain ulit or is it possible na higupin from the engine cap? lol.
    Nov 2003
    #816
    di mo sya mahihigop from the cap. you either need something to insert into the dipstick hole or drain it from the drainplug,
    Feb 2013
    #817
    Nov 2003
    #818
    you can use either or all naman. 10w30 was just my preference.
    Oct 2011
    #819
    Quote Originally Posted by speedyfix View Post
    ah okay, thanks sir speedyfix.
    Feb 2013
    #820
    paps, I am planning to roder this weekend sa website, orig ba yung Royal Purple nila dito, and ok lang ba gamitan ng Vic C-111 filter?
Royal Purple Oil
