Sir speedy, ask ko lang po kung may available na kayo sa shop ng 15w40. nung last punta ko po kasi 1 gallon na lang ang natira, kailangan ko pa ng 1 gallon pa po ulit.
for the city, use a 5w30 or 10w30. both are 2700 for the package.
sorry we're out of stock of the 15w40. you can try hans tools in shangrila mall or philshopping.com they should still have it.
if you want you can also mix the 10w40 engine oil. we only have it per quart here in the shop though.
thanks,
migs
Sir good evening.. ilang quarts po ba ang magagamit ko sa mini dump truck ko (isuzu 4BE1 engine)??? Im planning to use royal purple oil kasi. And sa tranny ano po ba marerecommend nyo na oil and ilan quarts din po ba???
Secondly anong viscosity po ba dapat??? Thanks po in advance..
i've got one last gallong pa of 15w40 pala left in the shop if anybody wants.
oil change interval can be 1 year or 10k kms for most gas engines. sooner for diesel engines since these run much dirtier.
4be1 uses 8-9 quarts of oil. you can use 10w40 or 15w40 for this. for the transmission and diff pwede yung max gear 75w90. we also have the 75w140 if you haul very heavy loads. i'm not sure if the rear diff but should be in the vicinity of 4-5 quarts. tranny should be around 3 quarts.
sir, kasama ba sa promo yung mazda 3? which uses 4.5 Qt of oil with Oil filter replacement
Ok, we went Royal Purple recently for our PROJECT MAJESTY Nissan Cefiro A32 Project Car at CustomPinoyRides.com, thanks to sir Speedy!
Check out the article here: CPR Project Car >> Nissan Cefiro A32 ?PROJECT MAJESTY? (Part 4) | CustomPinoyRides.com - Pinoy Pride In Our Rides!
Hi, what might be the recommended grade for a 2002 Camry (2.4li 2AZ-FE engine) with 58K km on the odo? I would also like to ask what filter would be used - is it also a Royal Purple filter? Can I bring my own filter (OEM) and have the price deducted from the promo price?
Thanks you very much!
chyll2, the mazda 3 1.6 engine will be 3300 since it uses 4.5. the 2.0 engine is not included in the promo since the oil filter price is different.
hypermileph, thanks for passing by bro! see you!![]()
corbon, you can use a 10w30. as with any toyota you may want to consider flushing the engine before using RP since the engine sludge problems might be happening on the engine. yes you can bring your own filter, in which case we charge you for each quart of oil and labor for the oil change.
Thank you migs.
Hi, if I may share, I've personally used Caltex' flushing oil previously. Difference I learned is it's not solvent-based, unlike most other motor flush which are and could lead to engine damage.
we use liquimoly flush and i'm pretty happy with it. it's not as strong as others but that's a good thing.
what can you recommend for mitsu mirage model and sportivo 2011 what is your contact number and shop located ?
anyone selling RP oil 15w40 that can ship via provincial bus transport (5-star or viron) to Pangasinan?
Try this seller on Sulit:
Royal Purple High Performance 15w40 Synthetic Motor Oil Philippines - 6779290
Maybe Speedyfix/Migs can send some via courier as well. Why not drop him a PM?![]()
Sir Speedyfix, gandang gabi po. Anong ATF po ang recommended nyo for 04' Sentra GX A/T? At ilang liters/quarts po ang kelangan? Baka drop by ako sa shop nyo po next saturday. thanks.
