Page 1 of 10 12345 ... LastLast
Results 1 to 20 of 1023
    Hey guys, any feedback on Royal Purple Oil? It seems to be in the same price range as Motul H100. I wonder, does it give the same protection, and performance as the similarly priced Motul? And would there be Royal Purple's for diesel?
    Jun 2006
    Royal Purple is good quality oil. Check mo itong thread: http://tsikot.yehey.com/forums/showthread.php?t=42843
    Eto naman website nila: http://www.royalpurple.com/
    They specifically recommend the 15w40 for diesel.
    Jun 2006
    recently used royal purple for my matrix crdi here... like any other oils out there so far okay naman...
    kay SpeedyFix Shaw ka kumuha ng Royaltru Orange...este, Royal Purple pala...
    Nov 2003
    yup the 15w40 is diesel rated. so is the 10w40 actually pero better to use the 15w40.
    chuaed, maling kulay yun bro! hahahaha!
    based dito sa test ibig ba sabihin eh mas maraming napasang tests yun 10W-40 compare sa 10W-30? so mas maganda ang 15W-40 dahil mas marming tests na pumasa?
    royal purple motor oil test
    Multi-Grade Oils — Typical Properts1, Part 2
    SAE GRADE / API SERVICE
    ASTM Tests
    10W30
    SL
    10W40 CF-4,CG-4,CI-4/SL
    15W40 CF-4, CG-4,CH-4,CI-4/SL,CI-4 PLUS
    Jun 2006
    ASTM Tests
    10W30
    SL
    The 10w30 and 5w30 is for gas engine only. Both are energy conserving oils. So your FC will improve a bit. Hard to put an exact number on your savings.
    The 10w40 and 15w40 can be used for both gas and diesel engines. The 15w40 is a better for diesels.
    Apr 2010
    Sir Speedy ask ko po kung ano ang maganda na engine oil para sa honda civic '"08. I think its says na 5W40 po. Kung gamitan po ng 5W30 okey din po ba?
    Aug 2008
    sir meron ba 5w50 ang RP at ok din ba gamitin ang 5w50 na mobil 1 brand. ano kaibahan nya sa 5w40 at alin ang mas ok gamitin sa 3sfe engine ng toyota rav 4 98 model.??????.......TIA
    Speedyfix,
    My subaru forester is due for its first 1,600 km oil change in MI. They recommend that we use Shell Helix Ultra 5W-40 which they are using. But since it's expensive (P750/liter), they allow you to bring your own oil (subject to P50 corkage fee). If I choose to get Royal Purple, which product do you recommend?
    Nov 2003
    nvidi.turion, wala pa nga sa visayas... Royal Purple only makes fully synthetic lubricants. it doesn't make mineral or semi syn oils. so any RP product you buy is sure to be fully synthetic.
    jmpet626, depends on your milage, anything from 10w30-10w40 is ok. we use Vic filters.
    wranglerboy, thanks for passing by the shop! seeya after 10k kms!
    mucho, the oil is still 550/quart. we only have quarts now and the gallons are out of stock but same price lang naman sya. most synthetics nga are group 3 base stocks. iilan lang sa philippines yung group 4 and above. 5w40 is ok naman as long as it's diesel rated.
    reijan, 5w30 or 10w30 is fine for your car.
    cal16, RP only has a 20w50 viscosity. it's fine to use if the milage is high but your engine will run better with a slightly thinner 40 viscosity.
    powerloord, for n/a foresters most customers us the 5w30 viscosity, but if you want to be close to what MI recommends then any of the 40 viscosities are ok. we have the specific 5w40 but it retails for 690 and not the normal 550/quart.
    exsior1111, either the 10w40 or 20w50 will do. depends din what you were using before.
    weszt, sorry... we don't deliver oil. 10w30 nga yung dapat gamitin.
    Aug 2009
    Sir Speedy
    San po pinakamalapit nyong shop na pwedeng mag pa change oil? Molino Bacoor Cavite po kami.
    Nov 2003
    we only have one shop here in shaw blvd in mandaluyong
    sir speedy, meron po kayong stock ng RP 10w30 ngayon? ill be having my pms later at your shop. sana di traffic
    Nov 2003
    yup meron pa naman
    Quote Originally Posted by speedyfix View Post
    yup meron pa naman
    ill be there later sir, sana may maabutan pa ako. just watching the finals.
    just been to speedyfix this after lunch. thanks sir migs. di ako nakapagpakilala sayo sir, nahiya ako e.
    infairness sa speedyfix, pagdating ko doon, larga na agad yung auto ko. ginawa na agad ng mechs. at paikot ikot si sir migs.
    Jun 2009
    Sir Migs / Speedyfix!
    Inquiry lang po... assuming po nag avail ng package for change oil, If your customer decided to replace spark plugs / fuel filter, do you allow to bring their own parts?
    Just an inquiry po. Thanks in advance.
    Quote Originally Posted by Smartbuddy View Post
    yup, i think sir migs will allow you to bring your own materials. but im not sure if they will charge for the labor.
    Jun 2009
    Quote Originally Posted by aejhayl17 View Post
    No problem with that sir importante they allow their customer... thanks sir!
    Jun 2005
    ah ok. sir yung 2500 promo sa site nyo iba pa rin yun? i might go there this saturday for the change oil.. thanks
Royal Purple Oil
