Add ko po pala...meron pa po kayong promo dun sa change oil? If so, anong viscosity recommended para sa ride ko? 1.3l QG13DE makina nya eh.
Hello Sir,
For L300 diesel ano pong oil pwede? Old car na. Regular use Shell oil. And for gear oil what do your recommend? Tks.
Hi Sir SpeedyFix,
Ask ko lang paso ba sa 2700 promo mo yung change oil sa Honda civic 2003? Saka anong oil filter ginagamit nyo? Also kung anong viscosity usually nilalagay nyo pag sa ganung sasakyan?
I might need to flush the engine oil also dahil ngayon lang ako magttry ng royal purple. Can you PM me for quotations?
Thanks!
Sir speedyfix, pag RP ginamit plus ung filter niyo, kaya ba every 10k or 1 yr OCI for a D4-D engine?
wutangclan_79 for the mirage 5w30, for the sportivo 15w40.
gaellazar yup back in stock na.
monty_GTV if you want one of our dealers to ship it, Al of HP racing is the best bet. the guy on sulit is not one of our dealers.
nowheeldrive 2-3 quarts lang for the atf. sentra falls into promo also
jdjoeydean for l300 the 15w40 and maxgear. but might be quite expensive compared to the mineral oil you're used to
yojstamaria yes pasok sa promo. we'll normally use a 10w40 or 10w30 for your car depending on milage. we use purolator. for the flush we'll use liquimoly.
retz, pwede naman to go up to 10k for the newer diesel engines.
Paps, sa innova VVTi 2008 model, ano po Royal Purple ang gamit, ilang liters and also how much per liter.
Thanks.
Pwede rin ba provincial orders sa inyo?
you can use the 10w30. you'll need 6 quarts. try ordering from PhilShopping.com | Online Shopping Philippines | Online Shopping
Total capacity is 5.4 or 5.7 liters (with oil filter already). I will check the manual later.
To avoid overfilling, Its better to put in 5 liters first and *slowly* top up until full. Use the dipstick as guide/reference. It will take less than 1 liter from the "L" to "F" mark
sir speedyfix, what if na overfill drain ulit or is it possible na higupin from the engine cap? lol.
di mo sya mahihigop from the cap. you either need something to insert into the dipstick hole or drain it from the drainplug,
ask lang paps, bakit di tayo pwede sa innova vvti ng Royal Purple SAE 5W-30 High Performance Synthetic Motor Oil or Royal Purple SAE 10W-40 High Performance Synthetic Motor Oil
