Results 1 to 10 of 3899
Threaded View
September 17th, 2013 05:02 PM #10
B131 is wider than BT223 pala pero almost same height, mas mura din pala BT223. Hindi ata puwede sa toyota 4cycle engine ang B131.
baldwin bt223, full-flow lube spin-on
baldwin b131, full-flow lube spin-on
When was the last time you changed them? If it's been a while, I suggest following your mechanic's...
Rubber boot question (repair or replace)
