Page 169 of 195 FirstFirst ... 69119159165166167168169170171172173179 ... LastLast
Results 3,361 to 3,380 of 3899
    Jul 2012
    #3361
    Quote Originally Posted by MrQ5 View Post
    May taga Davao ba dito?
    Im planning to my next oci from delo 400 to Schaeffer Oil if the price is not that high.
    goodmorning bro. what about Mobil Delvac MX 15W 40 had you tried? for 7k km + Baldwin filter B-109 it really works and makes engine clean.
    Jul 2012
    #3362
    Quote Originally Posted by axe23 View Post
    Until now ng bback read pdin po ko.. Pero di ko pdin malaman kung anung code yun sa fuel filter pang adventure diesel na baldwin brand or any hi end brand. Wala kasi ako alam na nagtitinda dito sa bulacan. Siguro sadyain ko nalang this week sa volmax para sure...
    bro. maganda ang VIC 306 oil filter ng 4d56 engine. pag bibili ka buksan mo yun box then silipin mo sipatin mo maige yun butas ng filter VIC 306 mapapansin mo yun mga elements and components ng filter maganda. for sure e-compare mo sa ibang VIC brand any model number makikita mo magkaiba ang design. maganda parin ang VIC-306.
    Jul 2011
    #3363
    sorry sir, I will try oils with moly additives. I'm a convert now to moly, I think its now safe how they formulated MoS2 for engine oils.
    Jul 2013
    #3364
    until now backread pa rin ako pero i have read some post regarding sa fuel filter ng frontier td27 engine tumawag rin ako sa volmax di daw pamilyar yung B7022 ng baldwin so wala stock , i also tried gigatrade wala rin stock any alternatives kung saan pa makakabili
    TIA
    #3365
    Quote Originally Posted by horge View Post
    TIA
    Oil filter yata yung b7022 boss. If wala talaga, try mo wix if not magbosch ka na lang sir.
    Jul 2013
    #3366
    yup oil filter yung B7022, thanks sir maghanap nalang ako bosch
    Jan 2012
    #3367
    Anyone who needs BD28 and BF7535? PM me.
    B161-S and Fleetguard LF3691 (B1402 equivalent) also available
    Apr 2011
    #3368
    Eto I got from dvldoc. Will be using them for my navara. Hanap pa ako ng fuel filter na better than Mann at cabin filter
    Sent from my GT-N7000 using Tapatalk 2
    Mar 2012
    #3369
    TIA
    If you can't find the Baldwin B7022, you can try the Fleetguard equivalent (LF3638) or the Donaldson equivalent (P557780).
    Oct 2004
    #3370
    Share lang po...
    Baldwin BT223 from Volmax Marketing
    Baldwin BT223
    Baldwin BT223 compared to ViC C-113 (BT223 has a bit larger diameter, but they have the same height)
    Oil filter mounting in the engine block (notice the fabricated engine support of 4A-GE 16V red top converted to RWD)
    Since BT223 has a larger diameter compared to C-113, I had to check the clearance from the fabricated engine support
    Hand-tightened
    When I have the time, I'll cut-open the used ViC C-113 (only about 1000kms since last oil & filter change) to see what's inside.
    HTH... ;)
    Jul 2011
    #3371
    gusto ko sana maglagay ng 2nd fuel filter, meron ba available dito sa pinas kagaya nito
    delphi 296 with deep glass bowl
    #3372
    Meron ako nakita sa ebay. Parang less than $50 lang. Wanted to install the same thing sa car ko before. But decided not to anymore
    Dec 2009
    #3373
    sir yung exactly ganyan wala ako nakita nyan dito na locally available nung nag modify ako.. what i did was to find something locally available at pwede mag fit sa gusto ko... ganito yung kinabit ko:
    Fleetguard siya na fuel filter FS1241B
    tapos meh kasama siya ng clear bowl na plastic sa bottom para mkita mo water and dirt contaminants
    meh kasama na din siya fuel filter head(most important dahil dapat match sila ng filter mismo)
    tapos fabricate ako sa machine shop o aircon shop ng fittings para sa kabitan hose...
    #3374
    Meron niyan sa Berrima.
    Dec 2007
    #3375
    Quote Originally Posted by miko101130 View Post
    Hi, did you install this in series with the stock fuel filter? How much was the total expense, if you don't mind?
    Thanks.
    Sent from my GT-N7100 using Tapatalk 4 Beta
    Jul 2011
    #3376
    salamat sir, maka inquire nga sa berrima baka pede pa-ship.
    Apr 2011
    #3377
    Saan yang berrima? Gusto ko ren nyan.
    #3378
    Quote Originally Posted by jay185 View Post
    https://www.facebook.com/berrimadieselphilippines
    Berrima Diesel Service - Philippine Premier 4WD Service Centre
    #3379
    *Jay, If you want modification with the Nav, i recommend to replace only the primary filter because the secondary filter construction is soo good that you don't wanna modify it not unless you could find similar filter construction (rolled media and standpipe), or be fitting FASS with inline pump.
    Another consideration to take, these engines does not have in-line pump or check valve to maintain prime. Fuel is sucked from the tank directly by the engine's fuel pump, so adding a 3rd filter is not a good idea since it will add restriction.
    I myself have been planning to replace the primary filter but could'nt see the necessity yet because OE filters are doing fine. Maybe i will consider this if i don't replace filters often, or if i do offraoading/ wading water, or getting fuel from non-reputable pumps. But either way, it will still be a matter of proper maintenance. The existing filters would still detect water and filter dirty fuel just like any filter.
    If you're really seious about this, get the Parker Racor marine 200 series 10micron at 15GPH, clear galss buttoms have built in WiF just like our primary filter. Your problem now would be the space, the existing is soo cramped already.
    Jul 2011
    #3380
    ano ba recommended flow rate pag crdi? sa ibang forum 45-75gph para di hirap yung crdi (pump/suction?)
Remote bypass oil filtration
