Share lang po...
Baldwin BT223 from Volmax Marketing
Baldwin BT223
Baldwin BT223 compared to ViC C-113 (BT223 has a bit larger diameter, but they have the same height)
Oil filter mounting in the engine block (notice the fabricated engine support of 4A-GE 16V red top converted to RWD)
Since BT223 has a larger diameter compared to C-113, I had to check the clearance from the fabricated engine support
Hand-tightened
When I have the time, I'll cut-open the used ViC C-113 (only about 1000kms since last oil & filter change) to see what's inside.
HTH... ;)
