Thanks for sir,
That is a nice upgrade then on your filter, You have almost double your filter size. Which means you can run your oil longer.
Don't think you can do this on the D4D engine, But I will check to see if it fits one of these days.
Looks like you have enough room for a B2 filter it's only about 2 inches longer. If that is the case on your next oil change I would check out Pacer for the LF3487
These are designed for extended oil changes, It's the microglass media and it filters down to 7 microns * 50 percent, I use a version of that on one of my cars. expect about 20000klm oil change interval with a good oil with a TBN of at least 10.
The LF3487 they carry is a made in USA one so it's the real deal. Just something t othink about next oil change in about 12000klm or so.
