I got that from a Virgin oil sample from Blackstone. The results will vary a bit depending on what lab does the test.
It's this one here. might be different than the one they sell there.
[IMG]http://hard****ing.com_www.maxlifeoil.com/admin/p10.png[/IMG]
But it looks like the formulation has changed since last year, They have two different specs one from last year and one for this year. This is due to the API rating. And as you can see the CI-4 is superior it's TBN is 12 while the newer CJ-4 is only 10. Damm EPA!!!
http://www.valvoline.com/pdf/premium_blue.pdf (CJ-4) (The phosphorus will be limited to no greater than 1200ppm)
http://www.valvoline.com/pdf/premium_blue_classic.pdf (CI-4) (no phosphorus limit)
Fortunately you guys can't get get good stuff all day long.
I would not use the Delvac 1, on a JDM diesel , It simply cannot keep your engine as clean.
