Hi. I was informed by a member that you might have some questions regarding filters. I am from Pacer and one of the dealers for Fleetguard filters in the Philippines. I will try to answer your questions as much as possible.
Regarding verification if the filter is counterfeit or not, I will have to see the actual filter and confirm this with Singapore. They will then check if the filter was produced by them and at what facility.
Regarding the size, Cummins Filtration does intensive research and warrants that all filters either conforms or exceeds OE standards. Although, the size may be a bit different, the quality will remain the same.
Regarding Titan Gold, we are the dealer for it. It is a relatively new filter produced by Cummins Filtration to handle the light and medium duty applications (Fleetguard is originally designed for Heavy and Off Road applications). Although, the stock for this brand is still a bit scarce, we are trying our best to increase supply to keep up with the demand.
If you have any questions, you may email me at
pacereqpt*gmail.com.
