Results 1 to 20 of 3899
Threaded View
    Dec 2007
    Quote Originally Posted by indiej View Post
    OT: do that And ignore all the troll's posts whatever the content. Do not reply to its posts (feeding). pls read about trolling, flame baiting.
    i'll bite, why do you often call it sYThetic? my question before is about the bypass filter. are you adding that to your product lineup in Devil's Own?
    i'm looking around at pvc pipe traps for an oil catch can but IDK if that can handle the temps.
    Yeah I am done with that guy. He's just embarassing himself.
    Now are you asking why i call oil or the oil filters synthetic? (I did type -o it a few times, fat fingers I guess lol) The filters you use for a bypass set up have to be a synthetic fiber or super high efficiency cellulose synthetic mix of filter media. This is the only way to effectively remove the particles that are less than 20 microns in size.
    PVC should have no issue holding up to engine heat as long as it’s not the thin cheap stuff. In my Grand Prix GTP I use a DIY PCV fenderwell intake system, never had a problem and it runs over the exhaust manifold.
    If you mount your catch can along the side of the car like on the fenderwell you should have no issues. Even the ones with the clear plastic bowls on air compressor oil separator hold up fine under the hood.
    And no we will never get into filters to many people speciallize in it already. I'm sure I will bring a few set-ups with me next year for anyone who wants to run one.
    Try foam, steel wool or a steel scrub pad for your catch can's media they work the best at trapping the oil particles from the incoming air.
Remote bypass oil filtration
