Results 1 to 20 of 3899
Threaded View
    Dec 2007
    Microglass p550 even surprised why its cheaper than the smallest LF300. Its an old stock though, but i inspected the internals its clean. The biggest LF3314 is p180 LF689 p200
    Does these lube filters have micron ratings too like the FS? cant find the info in the specs.
    Dang those are good prices, Mine are new old stock as well. Basic Cummins standard is 96.6% 20 microns. Probably should keep it on the down load how good those filters are or they will raise their prices for sure.
    I'm pretty sure your LF3314 is a fake, the dead give away is the fact it is plastic wrapped at the bottom only, Only the China fakes come like that. Does it have a country of origin on it? Like I said they come full plastic wrapped on every one I have ever seen. Compare it with the one I posted, The font should also be black on that filter for the word FLEETGUARD. Hey you scored big time on the rest.
    compare that LF3487 vs a stock Nissan filter.
    Amsoil (hope the name does not draw out the crazies) lol uses the same media in there high efficiency filters.
    Nissan should be ashamed to even make these.
    And a basic fleetguard.
    At least in the states it's illegal for your warranty to be voided because of a oil filter. It's called the MOSS Act.
    The Microglass media filters are good for a easy 20000klm with synthetic oil. If you got a adapter set you could make a bypass setup with the Miicroglass media one double that.
Remote bypass oil filtration
