Since you can find these there now, Here's a few part numbers for you guys for your rides.
BT223, B7243, LF3335 fit all Fortuner, innova, and Hilux. gas or diesel or any Vic C-111 or Union C-171 or C-172
LF4056, B2720 Fit Nissan Elgrand, 2.0 largo 2.0 turbo diesels, Nissan Vanette CD20ETI, LD20T, CD20T engines, QD32ETI, TD27TI. Or any vehicle that uses VIC 226.
LF551A, LF3314, LF689, LF3487(UPGRADE SYNTHETIC MEDIA FILTER)
Wil fite all 2.5TD, Rangers/Everest/Mazda Freidee/Ford Feda basically all WLT 2.5 turbo diesel engines. Or any vehicle that takes a VIC 209 or Union C-221 also VIC-115 and Union C-151.
Also fits all
D21 TD27 6/92-2/97
D22 TD27 2.7L 3/97-01
D22 QD32 3.2L 3/97-01
D22 3.0TD 2002
GQ TD42 11/87-8/89 and on, Turbo and non turbo engines.
HILUX 2.4D, HIACE2.5D 96-, POWERVAN 2.4 97
Ford sports Track
Ford V-8's till 2005
B163, B34, LF3604 (Not pictured because I don't feel like moving to big boxes of filters to get to them)sorry.
Fits Navara YD25DDTi will also work on all the ones for the Row with LF551A,LF3314,LF3487, LF689
Fortuner, Hilux, Innova, D4D and 2.7 will fit these.
I pretty much databased all the high end filters with all the cars there and stocked up on them for a hobby gig when I retire from the Navy, Get bored with the water injection sometimes. lol.
Here is my bypass filter set up minus the filter adapter which I am still waiting on but this is what it looks like. Except i am not using the barbed fittings but Push lock fittings with 8AN ends. I don't care for barbs and hose clamps that much.
This is my Bypass system set up. I am using a Full flow Luberfiner imperial XL full sythetic media filter. With a Fleetguard LF3947 (stratopore) full sythetic 5 lay media (best filter money can buy). Again you can't go to your local parts store for these filters.
Specs
The LFP780XL is a 5 micron * 50% and a 20 micron * 98.67% filters 2 microns absolute at 36%.
The LF3947 30 Micron at 99% and a 10 Micron at 85% efficient 5 microns 78% efficient on the first pass. 2 microns absolute.
I was going to use the LF3487 which is the sythetic media as well but the microglass which is the same thing as Amsiol, The Statapore has 5 different layers. You can also see the size difference these are about 7 inches tall. And will be good for 40000KLM oil changes with changing the full flow every 20000klm and the Bypass at 40000KLM.
I also am adding a Isspro oil pressure gauge and Nordskog oil temp gauge to keep a eye on everything using a sandwich adapter on the bypass filter.
You can see the Amsoil and the Fleetguard microglass media is basically the same. Both the filters I am using exceed the Amsoil in filtration ability but not by much.
Interesting video on bypass systems.
[ame="http://www.youtube.com/watch?v=rKBs6KGcgwI"]YouTube - Amsoil Bypass Filters[/ame]
