Results 1 to 10 of 15
December 16th, 2008 11:37 AM #1
I haven't done it and don't dare do it, but out of curiosity what happens if you start the engine when the pre-heat indicators is still lighted?
December 16th, 2008 11:38 AM #2
Hindi siya mag start mag redondo lang some times it will start............yun lang po.
December 16th, 2008 12:13 PM #4
December 16th, 2008 01:55 PM #5
I tried it many times when I just learned how to drive, nag sta-start naman. and I also realize one ride of ours, even the indicator in the dash is off, the heater is still heating. I have attach my own light indicator directly to the glow plug.
December 16th, 2008 02:31 PM #6
tidus, is it for the santa fe? how many sec. before the light go out? thanks
December 16th, 2008 02:39 PM #7
December 16th, 2008 02:47 PM #8
normally pag may glow plug it takes a few seconds and sometimes gets even longer depending on the condition of the plugs and/or battery.....the crosswind don't have them. straight start agad.
- Jun 2008
- 63
December 16th, 2008 05:32 PM #9AFAIK mas madaling masira yung engine at cold start kc malapot yung engine oil at low temperature
December 16th, 2008 05:40 PM #10
as if maabutan mo buhay pa yung indicators ng glowplugs.
sa delica ko noon or sa liteace less than 1 sec lang even * coldstart sa baguio ng dec-feb. original glow plugs. pag ung tig-100-250 lang japeyk yun, madali lang buhay nun...
well diesels need heat to combust fuel kaya nga may ganun e. gasolines just an ignition.
Good point on that. But the hybrid one which will give you a ton of savings on fuel maybe worth it...
Mitsubishi Xforce
