Results 1 to 15 of 15
    I haven't done it and don't dare do it, but out of curiosity what happens if you start the engine when the pre-heat indicators is still lighted?
    Jun 2008
    Hindi siya mag start mag redondo lang some times it will start............yun lang po.
    Ah ok so may fail safe naman pala?
    usually mas mahaba ang redondo pero minsan hindi naman.
    pero mag start talaga yan.
    I tried it many times when I just learned how to drive, nag sta-start naman. and I also realize one ride of ours, even the indicator in the dash is off, the heater is still heating. I have attach my own light indicator directly to the glow plug.
    tidus, is it for the santa fe? how many sec. before the light go out? thanks
    Yes sir for Santa Fe. Mabilis lang po around 3 seconds lang, pero this is just a question of curiosity. Just wondering if its damaging to the engine? Of course, I can always afford 3 seconds no problem
    normally pag may glow plug it takes a few seconds and sometimes gets even longer depending on the condition of the plugs and/or battery.....the crosswind don't have them. straight start agad.
    May 2007
    nothing happens to your engine. the pre-heat is used to help increase the temperature of air/fuel mixture in the chamber for easy combustion coz' diesel engines don't have spark plugs.
    if the pre-heat stays too long the glow plug will be busted. diesel engines with very good compression will start even without pre-heating.
    Wala naman. YOur heater still works for a couple of seconds after your engine has started. It's just to guarantee a quick start. Observe that during the rest of day you don't really need to wait for lamp to turn off or it just goes off after a second or two.
OUT OF CURIOSITY: Regarding diesel pre-heat...
