you might tighten the valve cover bolts a bit, if you are in a financial bind.
if it does not stop the leak, and i believe it won't, what with its age, then replace it (the valve cover gasket).
it's just a valve cover gasket, sir. it's not that expensive. but if the oem is too expensive for your taste, use a cheaper replacement brand. the stresses there are "not too much", i feel even a cheaper gasket will do fine.
good luck.
