you might tighten the valve cover bolts a bit, if you are in a financial bind.
if it does not stop the leak, and i believe it won't, what with its age, then replace it (the valve cover gasket).
it's just a valve cover gasket, sir. it's not that expensive. but if the oem is too expensive for your taste, use a cheaper replacement brand. the stresses there are "not too much", i feel even a cheaper gasket will do fine.
good luck.
Quote Originally Posted by K.I.L.L. View Post
They usually call this service a top overhaul.
Sent from my Android using Tsikot Forums mobile app
Mga sirs, estimate price po ng top overhaul? Para mpag handaan. Thanks! Medyo tight ang budget kaya kailngan sure na pag pinagawa. Thank you!
