Yung price ng job order mo bro will depend kung sino gagawa... that's your job to canvass.
Regarding sa bilihan ng parts, you can try asking at Mazford sa Pasay city. Dun ako nakakuha dati ng fair price para sa head gasket.
Other tsikoteers can also provide recommendation kung saan ka pwede bumili ng parts mo and kung may recommended shop sila.
Sent from my ASUS ZenFone 4 using Tapatalk
Mga Sirs, need ur expert advices!
Newbie lang sa car.. minana ko sa erpat ko yung Toyota Corolla Small Body nya.. ginagamit ko na siya for almost 1 year.. my problem was nakikita ko dun sa engine nya may nag lleak na oil then hnggang sa spark plug may oil na din.. mahina lang naman siya mag bawas ng oil... tapos okay pa din naman manakbo. Ano kailangan ko gawin? Hindi ko naman madala sa shop kasi hindi pa ko sure sa mga kailngan ipagawa.![]()
it is the valve cover gasket. for an old car. there could be more things to do. we have a gasket keep things in and out. replace as soon as possible.
1998-2008 Toyota Corolla Valve cover gasket remove and install - YouTube
you might tighten the valve cover bolts a bit, if you are in a financial bind.
if it does not stop the leak, and i believe it won't, what with its age, then replace it (the valve cover gasket).
it's just a valve cover gasket, sir. it's not that expensive. but if the oem is too expensive for your taste, use a cheaper replacement brand. the stresses there are "not too much", i feel even a cheaper gasket will do fine.
good luck.
They usually call this service a top overhaul.
Sent from my Android using Tsikot Forums mobile app
First car ko toyota corolla small body and i must say very easy to maintain siya and durable.I used to do the change oil,spark plug replacement and adjustment ng contact point...that's how easy to maintain it.
Should you have budget,pa top overhaul mo na sir and check valve seals and guide.
Sent from my Redmi Note 4 using Tsikot Forums mobile app
Hello tsikot. Any reputable shops around mandaluyong or malapit na marerecommend ninyo pra magpa full overhaul? H100 ang car. Tia
