Page 3 of 3 FirstFirst 123
Results 41 to 53 of 53
    Jul 2017
    #41
    Quote Originally Posted by jodski View Post
    Kung palit head gasket yan it will go around 7 to 15 k depende kung saan ka magpapagawa kasama na parts.
    Mag canvass ka muna kung magkano head gasket mo and as much as possible yung original.
    Sa shop naman na hahanapin mo. Go ask them if they have a torque wrench. I research mo na rin kung ilang torque ang kailangan para sa unit mo... hindi kasi pwede yan sobrang higpit at lalo na hindi pwede na maluwag
    Sent from my ASUS ZenFone 4 using Tapatalk
    Sir jodski salamat po sa help nyo... ask n lng dn po ako if san po mganda mghanap ng murang parts ngn mazda 3. Ang quote po kc sa akin ng pagawa ng top overhaul eh mghanda daw ako ng 30-50k. Tama po b un?
    Sep 2012
    #42
    Quote Originally Posted by rcdgreat View Post
    Yung price ng job order mo bro will depend kung sino gagawa... that's your job to canvass.
    Regarding sa bilihan ng parts, you can try asking at Mazford sa Pasay city. Dun ako nakakuha dati ng fair price para sa head gasket.
    Other tsikoteers can also provide recommendation kung saan ka pwede bumili ng parts mo and kung may recommended shop sila.
    Jul 2017
    #43
    Sir jodski ang laki ng price diff ng price ng gasket between orig vs replacement. Ask lng po if ok n b gmitin is replacement lng?
    Sep 2012
    #44
    I would suggest you get the original.
    #45
    what are their prices, po?
    Nov 2017
    #46
    Mga Sirs, need ur expert advices!
    Newbie lang sa car.. minana ko sa erpat ko yung Toyota Corolla Small Body nya.. ginagamit ko na siya for almost 1 year.. my problem was nakikita ko dun sa engine nya may nag lleak na oil then hnggang sa spark plug may oil na din.. mahina lang naman siya mag bawas ng oil... tapos okay pa din naman manakbo. Ano kailangan ko gawin? Hindi ko naman madala sa shop kasi hindi pa ko sure sa mga kailngan ipagawa.
    it is the valve cover gasket. for an old car. there could be more things to do. we have a gasket keep things in and out. replace as soon as possible.
    1998-2008 Toyota Corolla Valve cover gasket remove and install - YouTube
    #48
    Quote Originally Posted by nogabz View Post
    you might tighten the valve cover bolts a bit, if you are in a financial bind.
    if it does not stop the leak, and i believe it won't, what with its age, then replace it (the valve cover gasket).
    it's just a valve cover gasket, sir. it's not that expensive. but if the oem is too expensive for your taste, use a cheaper replacement brand. the stresses there are "not too much", i feel even a cheaper gasket will do fine.
    good luck.
    #49
    They usually call this service a top overhaul.
    Sent from my Android using Tsikot Forums mobile app
    Nov 2017
    #50
    First car ko toyota corolla small body and i must say very easy to maintain siya and durable.I used to do the change oil,spark plug replacement and adjustment ng contact point...that's how easy to maintain it.
    Should you have budget,pa top overhaul mo na sir and check valve seals and guide.
    Sent from my Redmi Note 4 using Tsikot Forums mobile app
    Nov 2017
    #51
    Sir, thank you very much sa expert advice... natatakot lang ako at baka bigla na lang akong itirik sa daan.. kaya from time to time check ako lagi.
    Nov 2017
    #52
    good luck.
    Quote Originally Posted by K.I.L.L. View Post
    Mga sirs, estimate price po ng top overhaul? Para mpag handaan. Thanks! Medyo tight ang budget kaya kailngan sure na pag pinagawa. Thank you!
    Jun 2009
    #53
    Hello tsikot. Any reputable shops around mandaluyong or malapit na marerecommend ninyo pra magpa full overhaul? H100 ang car. Tia
Need na ma overhaul yung engine?
