Page 143 of 200 FirstFirst ... 4393133139140141142143144145146147153193 ... LastLast
Results 2,841 to 2,860 of 6586
    Aug 2015
    weird, multiple posts.
    Aug 2015
    hey guys, why are thicker oils recommended for older engines in general? Does that mean pwede magbago ang recommended oil as the car gets older? Is it to protect and prolong?
    Quote Originally Posted by unmarked View Post
    Sa pilipinas lng ata popular yan. Most asean countries have been using 5w30 since the 2000s.
    Lots of good stories about xw20 over 200k miles sa bitog forums but these are from the americas.
    The shift will be lighter viscosities in the future..
    Aug 2015
    Ang assumption sa atin kasi ay may leaks na ang old engines. Low viscosity oils (thinner) is able to seep easily out of the engine through the leaks. Kung okay naman ang seals ng engine, wala naman siguro masama gumamit ng thinner oil.
    Recommended oil for an engine does not change IMO. But bear in mind that higher rating for oil is usually backward compatible.
    I see, thanks. Nakita ko kasi to:
    when I read the article ung Hx3 kasi 20w-50 yan. I've used Gulf 20w-50 before by mistake, and grabe ang ingay ng makina. Performance was still the same, sobrang ingay lang talaga, hindi tama. Nung nagpalit ako, sabi nung mekaniko ang lapot daw sobra LOL.
    Jul 2013
    Kahit Anong oil pa Yan as long as ok yun viscosity for you and you change oil regusrly, I don't see any problem.
    Many owners miss changing their oil at the right interval.
    Hence a fully synthetic oil is good recommendation. Even if they miss the change by 3-12months at least their engine will be useable.
    Affordable mineral oils dont last as long.
    Hx7 pinaka maganda sa list mo bro
    Sure ka ba magnatec nilagay? Did you see green or white bottles? White ones are castrol gtx and are mineral. The magnatec oils are very good. Ano kaya viscosity ng nilagay ng mechanic?
    Oct 2016
    uy salamat stockengine sa reply...ang bilis...yun nga talaga nasa toplist ko sa mind ko lang...nag-add lang ako baka kasi sakali mas may okay pa.
    Pahabol na katanungan kung okay lang....oks lang naman cguro HX7 langis ko kahit XCS ang gas ko wala naman siguro problema? Habol ko kasi sa Petron yung points
    thanks ulit
    Engine oils are for lubrication and is not mixed with fuel. Hehehhe
    Go for any fuel. Basta palet fuel filter regularly 40k..
    Oct 2016
    salamat stockengine sa reply....really appreciate it.
    mga sir tanong lang kung ano magandang fs oil for tucson 2011 gls.
    Quote Originally Posted by burnik View Post
    Most fs oils conform to different requirements. Engine oils are of diesel and gasoline varieties.
    In your owners manual it will say which type of oil it requires.
    Question is... is your tucson diesel or gas?
    thanks sa mabilis na reply sir. gas po yung tucson ko.
    Aug 2010
    between this oil, ano mas preferred nyo gamitin pang diesel?
    Mitasu Turbo Diesel 15w40 - 1200/Gal
    Mitsau Diesel Ultra 5w40 - 1700/Gal
    Top1 Hd Plus 10w30 1575 / 5L
    Zic x7 10w30 - 1500/4L
    Quote Originally Posted by igiwtf View Post
    6L yung Zic X7 10w30
    Jan 2009
    Just to be more accurate, there are motor oils that are designed for both gas or Diesel engines. These would have an API marking such as SM/CF. In simplest terms, it means that it is suitable for gas engines that require an API SM oil as well as Diesel engines that require API CF. Assumption here is that you're already using the correct viscosity.
    Mineral oils...
    Completely mistaken. X7000 and x9000 are hdeos from zic. FS 15w40s.
    "New oil more often" - more harm than good. Everytime you drain and fill doesnt protect the areas (where oil should have been) during engine start/ignition. A brief discussion of this was in bitog forums. Wish I bookmarked it. Cant find it anymore.
Mineral , semi synthetic or fully synthetic?
