Page 155 of 200 FirstFirst ... 55105145151152153154155156157158159165 ... LastLast
Results 3,081 to 3,100 of 6586
    Mar 2013
    Para sa walang pera o budget, any castrol motor oil plus 1 can of pertua metal treatment or oil additive pwede na malaking ginhawa sa chain, rocker arm, crankshaft bearing. Mapapansin mo na kagad maslalo na pagstart mo sa umaga tahimik at mabilis ang redondo sa diesel engine man. Sa halagang 350 pesos dont know lang ngayon, masisiyahan kana. Around 80's and 90's oil chnge lang using regular or special oil ng gas station sulit na. Pwede rin sa scooter or motorbike ganda ng hataw. Share lang po para sa mga walang budget hehe but performance wise ang pertua.
    Apr 2014
    Since 230-250 lang per liter yung gamit ko na FS, sulit na 1k-1.5k na budget sa oil per car per year.
    Sent from my MI 5 using Tapatalk
    Quote Originally Posted by fireice2 View Post
    Ano po brand ang FS oil ninyo? Thanks.
    Jun 2017
    Mga sir anong oil gagamitin ko sa 2010 toyota fortuner (diesel) odo nya nasa 77kms? Na aquire ko kse 2nd hand yung sasakyan at gusto ko ako na lang mag change oil, saka anong magandang oil filter? Thanks
    Feb 2017
    Quote Originally Posted by endoo View Post
    Try mo sir Delo 400 or pag may budget Motul crdi 👍
    PAJ 4M40 MORE POWER!
    Apr 2009
    Im currently using havoline 20w50 for my 1997 corolla gli 1.6. Im planning to change to the new shell high mileage sythetic motor oil which is 10w40. Should i proceed with the change of oil?
    Apr 2006
    Quote Originally Posted by bail View Post
    what's your goal on switching?
    if your engine is running fine, there's no need to switch.
    what does the owner's manual say, po? i'd probably stick to it.
    Sep 2012
    Matagal na ba naka 20w50 yan?
    If you are planning to go ahead with 10w40 mag prepare ka na rin ng budget for valve cover oil seal replacement just in case may mag leak dyan after the switch.
    Sent from my ASUS Zenfone 3 using Tapatalk
    Feb 2017
    sir meron po ako tanong sa mga experts dito..
    gusto ko sana gamitin yung MOBIL DELVAC 1 full synth for Isuzu D-max 2017 LS po. pero nakalagay sa manual MOBIL DELVAC MX which is synth blend. ok lng ba full synth gamitin ko? ano kaya safe na ODI?
    sa friend ko Monty ride nya gamit din siya MOBIL DELVAC 1 pero ODI nya 15,000 km. tapos sabi ng clasmate ko nagwork sa MOBIL kaya dw 25,000 km to 40,000 km ang ODI ng mobil full synth or 1 year whichever come first.
    pero kadalasan nabasa ko pag full synth 10,000 km ODI tapos pag semi-snythetic 5,000 km po.
    need lng po advice ano maganda ODI na safe ng engine po.
    maraming salamat po
    Quote Originally Posted by Nakishus View Post
    maraming salamat po
    Aside from delvac one you might also want to compare mobil turbo diesel truck (also fully synthetic) but beware of fakes.
    new oil for the daily...
    Aug 2016
    How much is this though?
    Sent from my SM-N920S using Tsikot Forums mobile app
    Im not in the Philippines. the shop said it was 600 originally. but haggled down to 540 per bottle (x4) with the oil filter change.
    Jan 2017
    Mga Sir's,
    Hingi lang ako idea kung anong ok na engine oil for Lancer 1997. High Mileage na din kasi. 100Kms+ na. Gasoline po. wala din po kasi ako owners manual eh.
    Salamat po.
    Quote Originally Posted by akris View Post
    Mga Sir's,
    Salamat po.
    what was the last oil used?
    Jan 2017
    Top 1 HP Plus po 10w-40.
    keep using the same oil. changing to another oil doesnt really help improve the engine.
    Jan 2017
    noted sir. thank you
    Feb 2017
    May nakagamit na po ba ng bagong release ng Delo products? Delo 400 MGX meron kasi sa Lazada kaso by 5L lang ung meron sila.
Mineral , semi synthetic or fully synthetic?
