Page 257 of 330 FirstFirst ... 157207247253254255256257258259260261267307 ... LastLast
Results 5,121 to 5,140 of 6586
    Aug 2017
    #5121
    Quote Originally Posted by marbintorres View Post
    hi. ok lang ba mineral oil sa turbocharged engine? i use the car very often (more or less 100kms a month). im currently using shell helix ultra fully synthetic. and i find it very expensive. btw car is a nissan skyline.
    Ok lang po yun but check api or acea rating to meet you car specification always.
    Sent from my SM-J700H using Tsikot Forums mobile app
    Jun 2015
    #5122
    is zic fully synthetic?
    Quote Originally Posted by goodvibes8888 View Post
    No. Meron variants.
    Feb 2015
    #5124
    Bakit sobrang mura ng zic engine oils?
    Yun FS oils nila, halos ka-presyo lang ng mineral oils ng iba.
    CI-4 rated naman.
    Fake? Low Quality?
    Sana naman hindi. Ito ang balak ko gamitin sa next PMS ko.
    Quote Originally Posted by makelovenotwar View Post
    CI-4 rated naman.
    Fake? Low Quality?
    Yun mineral oil nila. Nakasulat lang na FS pero hinde pag binasa mo
    Feb 2015
    #5126
    Aw.
    Ito nakita ko lang.
    http://www.skilube.com.my/ZIC-CATALOGUE-CONTENTS.pdf
    Hindi pa ako nakakakita ng actual na product.
    Yung Zic x7 yung balak ko gamitin. Nasa page28 nung document.
    May 2017
    #5127
    i am using semi synthetic, then replace every 5,000 km.
    I think na max ang every 5000 km chankge oil pag mineral, i think better kung mga 4,500km or less ay palit na.
    I agree with you Meledson.
    I change mine every 5k regardless of vehicle new or old. It's all about removing the dirt not how long you can keep it in the engine for.
    The big push for longer interval oil changes were not from the car manufacturer's but from the so called green earth environmental people.
    If they want to be green focus on recycling and trucks, buses and jeeps spewing out thick black smoke not the common motorist.
    I'm from Australia and now reside in the Philippines and since I had my first car until my latest 2016 my target is always 5k more or less for oil changes you can't go wrong. I never used a catch can or blocked egr and never had any bad carbon build up either or turbo issues. NEVER had any sludge as well.
    I use a semi synthetic oil any good proven brand but If a mineral oil only I use mobile Delvac due to its additives.
    Others will debate that 7k-10-20k oil change is ok but with me the more regular you change the oil the more healthier your engine will be in the long run for your turbo, egr and piston ring wear.
    If it's a truck well that's a different story and topic as most run fully synthetic and can do 10k in a week of continuous running.
    In tI'm end it's not what oil you use but how often you change it.
    Sent from my SM-J510GN using Tsikot Forums mobile app
    Aug 2006
    #5128
    ganun ba sir? sabi kasi nung kausap ko FS daw yung kanila..i was about to recommend it to a friend who's warranty just lapsed few days ago..due na sya this month and sabi ko nga medyo mura yung ZIC, then FS na..i double check ko nga yung picture na sinend nung seller sa akin...baka regular oil lang yun ah...
    Jun 2011
    #5129
    Curious lang: If the oil darkens or gets black after few months use, does it mean the engine is dirty? or the oil is of poor grade. I tried using synthetic oil 5-10W and got better result. My sparkplugs burns ideally as evidenced by the color of the plugs which is rusty red shade. and even on cold mornings i dont experience cold starting. thanks in advance
    for diesel engines, the soot&acid does darken the color much faster
    for petrols it does darken but at a later date.. ss oil and fs oil so far darkens around 3000km or 75hrs(engine running timee) for my vehicle.
    its normal..
    Mar 2015
    #5131
    hello mga masters
    ask ko lang if may naka experience na po sa inyo mag switch ng
    API SM to API SN and saw / experienced any significant difference?
    thanks po
    not that significant in theory. even my 2014 car only requires api-sl.
    tbh i havent seen any api-sm oils..
    whats the vehicle in question?
    api-sm 2010 and older
    api-sn this is somewhat current
    api-snrc this is current.
    Mar 2015
    #5133
    vios po na 3rd gen
    since my odo is expected to hit 15,000km this saturday, i had to look for replacement baldwin bt223
    the other guy whom i bought it from last year suddenly does not respond anymore so looked for another
    too bad the only seller i found requires me to buy oil along with the filter (understandable since COD for a single filter is just not worth it)
    unfortunately the best oil he offers is a fully synthetic API SM one (ZIC XQ 5w40)
    my engine is currently loaded with Helix 7 (which is API SN)
    what does your owners manual say? does it require api-sn or older?
    Mar 2015
    #5135
    SL, SM and SN are allowed on the manual
    just wanted to know if there are any easily felt (non placebo) effects between SM and SN
    nada...
    Mar 2015
    #5137
    thank you po sa info
    Jul 2014
    #5138
    Quote Originally Posted by sylphunter View Post
    vios po na 3rd gen
    May nakita ako sa shopee na nagbibenta ng baldwin filters. Free shipping pag P500 and up.
    Sent from my SM-G7102 using Tsikot Forums mobile app
    Aug 2017
    #5139
    Is it better to get Toyota's synthetic oil an 654/L but every 10,000kms and change interval, rather than the regular one na every 5k kms?
    Sent from my EVA-L19 using Tsikot Forums mobile app
    #5140
    Quote Originally Posted by willownavarro View Post
    may nabasa ako dito na mas maganda parin mineral with shorter interval vs. synthetic with longer interval. pero case to case din like red_one, iirc once a year sya magpalit (fully synthetic) kasi low mileage per year use nya.
Mineral , semi synthetic or fully synthetic?
