Page 194 of 330 FirstFirst ... 94144184190191192193194195196197198204244294 ... LastLast
Results 3,861 to 3,880 of 6586
    #3861
    Normally pag sagad ang gamit ng sasakyan, pina flush ko ng mumurahing oil bago ilagayj yung oil na gagamitin ko para matangal yung lumang oil.
    Aug 2010
    #3862
    may naiwan pa na oil from your previous oil change. give it another oil change to feel the difference.
    i saw how my mechanic drained the oil pan.
    he put 2 liters of diesel to the engine to dilute the oil before draining. then used air compressor.
    mga 2 hrs after draining the pan, (simut na simut) bago kinarga yung delo 400.
    1st time ko lang na experience yung ganyan. been using top1 sdo before trying delo.
    Quote Originally Posted by trucker111 View Post
    just want to give my feedback on delo 400.
    change oil 2 weeks ago using delo 400. drove 100km since....
    I say very disappointing. hindi madulas, mas umingay yung engine.
    problem is... there's still 4900km to go
    i'll give it 2/10
    What was the oil before?
    Apr 2014
    #3864
    Sana hinde pina start yun engine after ilagay yun diesel. Nakakpalambot kasi ng mga seals yan. At sana yun air compressor meron air-water separator.
    #3865
    May Buy 5 take 1 promo daw ngayon for DGU. Buy 4 take 1 naman for Delo Multigrade.
    May 2012
    #3866
    just bought a jug of top1 hd plus diesel engine oil - crdi. is this a "real" synthetic diesel oil o only marketed as such?
    actually this is my 2nd straight time i intend to use this but ever since my zic debacle i want to be sure na if what i'm buying is a genuine synthetic oil.
    btw, i'm pairing it w/ a baldwin oil filter as usual.
    ito siya: TOP 1 HD Plus Diesel Engine Oil ? CRDi « Top 1 Oil
    Top 1 sdo naman ang gamit namin for montero. Nakaka 2500kms pa lang. How much kuha mo sir?
    Mar 2011
    #3867
    On Top 1 SDO for 40k km already.
    Jul 2015
    #3868
    i'll give it 2/10
    Sabi ko sa inyo overrated ang delo oil. Ginamit ko yan sa 12 rent a car montero. Pati sa taxi ng family business at ng relatives. Ilan beses namin inulit dahil mura din bigay pero wala talaga ang gaspang ng takbo. Same with shell gaspang na pigil takbo.
    So its better to try the oil and compare.
    Aug 2009
    #3869
    Currently trying Pertua's Exello oil for diesel engine. So far smooth even on start ups and ok acceleration.
    Aug 2010
    #3870
    Quote Originally Posted by amoyligo View Post
    I think that's the right adjective... magaspang ang takbo.
    nakakainis din kasi lumakas ang vibration.
    4850kms to go
    malamang mga 3000kms palit na.
    will probably try zic x7 10w30 next unless somebody will give negative feedback on this
    #3871
    4850kms to go
    Sir, i have the same oil for my upcoming change oil this coming weekend. first time to try these formulation of zic. Dati Zic RV ako and Top 1 SDO. I believe your ride is a TCI starex?
    Jul 2013
    #3872
    My Innova currently have Delo Gold in it.
    Coming from Toyota Fully Synthetic, I'd say it is good in its first 1000kms.
    I have to see if it will maintain its performance until the next oil change (after 3,500kms or 4 months). Yes, I am experimenting on 3 oil changes in one year (instead to two) using mineral oil.
    Quote Originally Posted by Lew_Alcindor View Post
    Please keep all receipts also an excel file hehehe. Its tedious but well worth the information and good when its time to sell the vehicle.
    Jul 2013
    #3874
    I already have a record book. I just need to write the necessary stuff. I did it with my old corolla.
    Mar 2015
    #3875
    Sir since you have quite an experience with oils could you recommend what oil can i try with my ride po? I am now using shell helix 5w/40 in my car. What other brands can you recommend po that is better for gas fed engines sir? Thank you [emoji4]
    Jul 2015
    #3876
    Business kasi kami kaya factor lowest price, current ratings.
    Ngayon sa business we alternate valvoline, zic, castrol. Subok na namin.
    For our personal car gamit ko for gasoline engine zic a+, castrol edge, synpower. Pag pumunta pinsan ko sa america sa kanya ako nagpapadala yung mga hindi available na oil locally pero hindi practical kasi problem consistency sa pag gamit.
    So kung sa metro manila ka bibili advice ko pinalowest price na rated dexos 1, ILsac gf-5, api sn for gasoline engine.
    Apr 2014
    #3877
    Quote Originally Posted by SkyFlakes88 View Post
    Sir, ano po auto nyo? Pwede mo rin po check sa owner's manual kung ano po ang SAE viscosity at API rating ang recommended. Then later saka natin pag usapan ang brands.
    Mar 2015
    #3878
    Sir Nissan Sylphy po manual. Sa manual po recommended 10w/30 but nun nag Pms po ako 1k nilagay nila elf 5w/40 then sa 5k at 10k pms ako na nagdala oil ko shell 5w/40 till now yun na gamit sir. I'm thinking po next yun castrol na brand po e. Your inputs are highly appreciated sir. Ty
    Jul 2015
    #3879
    Try mo yung edge medyo mahal lang or kahit yung green magnactec 10w40 ok na.
    Pero check api rating baka luma ibigay sayo.
    Like idemtisu api sm pa din. No ilsac rating.
    Mar 2015
    #3880
    Dapat po sir SN rating? Thank you po sa reply sir [emoji4]
    D po ba mas maganda yun 30 kesa 40 sir?
Mineral , semi synthetic or fully synthetic?
