Page 184 of 200 FirstFirst ... 84134174180181182183184185186187188194 ... LastLast
Results 3,661 to 3,680 of 6586
    if you own a bimmer benz or bentley.. you better follow your owners manual or any vehicle for that oil matter.
    If one can source synthetics that pass Euro OE specs at around or a lil over the cost of American, which mostly are refined dino oil labeled as full synthetics, then, why not?[emoji4]
    look at the wear
    look at the wear
    The chart there says everything. The A3/B4 is much more protective.
    Not sure if there was an upgrade to ACEA 2010.
    What car do u have? Do you have owners manual? What does it say sa manual?
    This is so we can advise u properly. Ü
    Quote Originally Posted by istan View Post
    majority requires fs now. ford and gm and Chrysler proprietary formulas require full synth base oil. and majority of europeans.
    I think only the japanese stil recommend api-sn because of the shorter intervals. mitsu toyota nissan subaru and mazda recommends.
    and guess which engines are most reliable lol.
    Feb 2014
    my ford specs a ford certification WSS-something something which are available as FS and semi
    if you open the USA user's manual for this engine it says "API SN" is acceptable
    so when my warranty expires i'll be using API-SN
    Quote Originally Posted by Vodka View Post
    FordMaz sellls Ford-spec Motorcraft oils for both gasoline and diesel engines. They have both 5w20 and 5w30 viscosities, with API SN Resource Conserving (SN+), ILSAC GF5 rating. The 5w30 costs 450 per liter while the 5w20 is 600+.
    Jan 2016
    Can I use car engine oil for the engine of my concrete mixer? The engine is a 6.5hp motor star brand. Thanks
    BTW, manual says use 4 stroke oil, 5w30, when I researched it, car engine oil is 4 stroke oil din right? Thanks again.
    Mar 2018
    While it will probably work, i think it's better to use 4t motorcycle oil.
    Sent from my ONEPLUS A3003 using Tapatalk
    mukhang tama nga.
    read it again carefully, po. does "4T" appear anywhere?
    Jan 2016
    Thanks for the reply Sir Ravenblack and Doc, I did not see any 4T written on the manual but then yes, it is similar to a motorcycle since it is air cooled.
    To play safe, maybe i'll just use 4T, as it is for 4-stroke and high temp motorcycle engine.
    Jul 2016
    ok lang pang car gamitin mo na oil sir kasi wala namang wet clutch yung engine mo, 4t oils are designed for motorcycle with wet clutch.
    Sent from my Redmi 6A using Tapatalk
    Just this morning I noticed na merong smudge of oil leak makita ko sa cover ng ilalim ng engine or skid plate pero hiblndi metal yung orig pa na parag rubber.
    Dahil nga sa smudge I went to a nearby tayler at duon makita nila na hindi na tighten yung drain plug and because of this 1/2 liter of engine oil ang nagleak.
    Yung last PMS ko is sa Toyota casa early this month mga March first week. Haaaayyy
    So I had to top up 1/2 litrt of 5w30 oil fully synthetic Total brand. Yung nasa engine oil ko is 5w30 fully synthetic from Toyota casa. Ok lang ba yung halo halong ibang brand although same viscosity?
    Haaay Toyota casa, akala ko mas mainam sila gumawa.....
    Jan 2016
    Salamat Sir Mokong!
    ^ i've been using mag 1 fully synth sa fd2 ko for several years now and i've had no problems w/ it naman.
    Actually mas gumanda pa nga konsumo kumpara noong naka zic fully synth ako
    Nov 2014
    Thank you sir, yung MAG1 mo ba eh same as the one i posted- FMX? Okay din namam ako sa Havoline Caltex, first time ko ginamit, pakiramdam ko at kung tama compute ko all throughout nag improve FC ko.
    Jan 2016
    Suki ka na Ng Mag1 Sir baludoy, madalas kita makita na mag post na naka tyempo ka Ng sale nyan [emoji16]
    Nakagamit din ako nyan, 2 or 3 times ata, pero namamahalan na ako kasi, for 1.9k complete oil change package na yan using mineral oil, tutal, every 6 months naman palit ko
    Sent from my Mi A1 using Tapatalk
    Yezzir. I try to stick to it kasi ayuz naman resulta sa akin sa fd2 ko.
    Hindi naman parati nakakatyempo sa sale pero pag may sale binibili ko na tapos stock muna sa bahay til change oil time [emoji3]
    Ang medyo paiba-iba ako ng brand iyong pang diesel namin. Pero i think sa caltex oil hiyang truck namin na
    Feb 2012
    I bought mine on sale for only Php1,400 at Rob Handyman a few weeks ago. (Madami sila chemicals for auto maintenance on sale).
Mineral , semi synthetic or fully synthetic?
