Page 92 of 330 FirstFirst ... 4282888990919293949596102142192 ... LastLast
Results 1,821 to 1,840 of 6586
    #1821
    A high tbn doesn't mean its better than an oil with lower. Tbn degredation should be measured. Newer synthetics generally have lower tbn but degredation is better.
    Sent from my GT-I9082 using Tapatalk
    #1822
    Quote Originally Posted by hiromi_777a View Post
    Does anyone have a link for the full specs of Top 1 SDO? I know I mentioned the TBN is 11 but this is just based on an earlier post in this thread. I don't know where they got the info. Wala rin kasi sa website ng Top 1 ang full specs.
    TBN ng Top 1 na pang diesel ay just 9.+. Available sa global web site nila yung full spec.
    Oct 2011
    #1823
    Quote Originally Posted by Djerms View Post
    Good point sir.
    Oct 2011
    #1824
    Quote Originally Posted by jresperanza View Post
    ako din waiting for 10% discount, kailan kaya next sale sa sm?
    Sir, depende yan. pagnapadaan ako sa ace tanong ko next sale nila kung kailan.
    #1825
    From BITOG:
    TBN, we all know that it is the measure of an oil's alkaline reserve, which is used to neutralise acids and protect the engine.
    The higher the TBN the more acid that can be neutralized. In practice, the higher the TBN the longer amount of time the oil can neutralize acids.
    TBN retention is what's important as some oils with a lower starting TBN will retain that number for a long time whereas others with a high starting TBN will quickly drop like a stone...
    That said, I would like to use oils with a high starting TBN, especially on LSD...
    #1826
    Kung alam mo yung respond the TBN for that of oil brand much better pero normally hindi. So normal lang yung kunin na oil ay yung me mataas na TBN especially na old school yung makina na pag gagamitan mo. Iba na yung approach siguro kung engine mo ay required to use an ulra low sulphur fuel.
    11.8 ang TBN nang Top 1 SDO.
    #1828
    RT, saan mo nakuha yang TBN value ng Top 1? Eto yung spec ng Top 1 na ginagamit ko 9.3 lang (5 liter per container). Dito lang ata sa atin available yung nasa lata na Top1 (1 quart).
    Sep 2012
    #1829
    Every payday starting at 13th mid month and 3 days before end of month.... Nagrorotate lang sila kung anung mga malls may sale...
    Lagi dumadating sa inbox ko yan sa office naging habit ko na na parang auto delete ginagawa ko kasi nakakasawa rin basahin
    Apr 2010
    #1830
    Thanks for the reply regarding TBN mga Sir. Yes, I agree na important factor ang TBN retention but what if like in the case of diesel wherein the TBN should be in the 10-15 range? Would an oil with a TBN of around 7 but high TBN retention do? How do we know an oil's TBN retention? Is it usually indicated in the specs?
    *nelany - The TBN of Top 1 SDO is 11.8, it is a different oil from Top 1 HD.
    OT: How do you know if your car requires fuel with ultra low sulfur content? Are these fuels yung V-Power Diesel (Shell), Turbo Diesel (Petron), etc..? I think this was discussed in the other thread (Diesel users that add 2T to their fuel).
    Here's the full specs of Top 1 SDO based on the PDF I got from them. Also got the list of authorised dealers here in our area. Props to Top 1 for the quick response and good customer support.
    #1831
    A ok. Comment ko lang sa SDO in can (1 quart) na available sa atin ay hindi siya available to global web site nila. Available lang siya sa site sa PI at hindi available for download yung technical sheet niya compared the global website. Yung TBN sa tech sheet ng global ay:
    1. HD Synthetic Blend (15W40) = 9.3 (this is the one I'm using)
    2. HD+ Synthetic Blend (10W30) = 9.2
    3. Evolution Full Synthetic (5W40) = 10.5
    Tama kaya yung binibigay ng Top 1 PI sa tech sheet ng product dito?
    #1832
    only VOA would confirm this...
    May na-download ako sir n Top1 all products. Andun yung sa Top 1 SDO na basehan ko.
    If you pm me your email, send ko yung file.
    #1834
    RT, no need I have the tech data sheet of the oil that I'm using. Also I won't be using SDO since hindi siya available sa pinag oorderan sa labas.
    Jul 2010
    #1835
    Bulok ba delo400?
    How come bihira ko mabasa na maging subject ang delo400 ? Or any delo products
    Oct 2011
    #1836
    okay naman ang Delo 400 pero mahal kasi mas mura pa DGU or MD Mx.
    #1837
    yes, Delo 400 is CI-4+ with higher TBN, compared to DGU and MD Mx which are both CI-4 grade.
    Delo 400 is a proven performer sa BITOG
    Oct 2011
    #1838
    may nakita akong Delo Sports Synthetic Blend 15W-40. Ito na rin ba ung Delo 400?
    #1839
    nope bro, according to google CH-4 lang, at mataas pa yung specs ng DGU CI-4, specifically TBN; 9.5 vs 10.2
    Oct 2011
    #1840
    pero synthetic blend ito sir. nasa Php350/Li din ang price.
Mineral , semi synthetic or fully synthetic?
