Page 1 of 5 12345 LastLast
Results 1 to 20 of 82
    Aug 2015
    Guys meron na ba sa inyo maka try neto? MagnaFuel.
    Laging lumalabas sa FB wall ko, so just wondering if this thing really works. Claims to reduce fuel consumption. Quick googling yields no real reviews from independent (not connected to the company) groups.
    I'm really interested, but im not the type who immediately buys something w/o prior research and reading reviews.
    TIA
    Quote Originally Posted by rainybhoy View Post
    TIA
    "if it really works as claimed, they'd already beaten a path to his door by now..."
    it probably works as well as putting two strong magnets around the fuel line.
    Aug 2015
    Finally got one from Google, but this one was reviewed way back in 2005 pa. --> link
    I guess this one is somewhat similar to MagnaFuel:
    "MIRACLE MAGNETS
    According to the people selling these devices, as gasoline flows past the magnet, the magnetic field will "break apart clusters of fuel molecules so gas burns more efficiently." Problem: Gasoline molecules aren't magnetic, not at all. But wait, there's more. If the fuel line is steel, as many are, the lines of magnetic flux will follow the fuel-line walls instead of passing through the fuel.
    THE DYNO SAYS: As we suspected, neither device had any significant effect on performance or economy."
    just report it to FB as a scam.
    TIA
    Parang ganito rin ang ina-advertise as FB ng Ertiga...
    Gmax Supercharged
    Gmax Supercharged G-MAX FUEL SAVER is a product of MHD Science enhanced with designed of Monopole Technology where strong focused magnetic field is introduced to alter the ionic charge of fuel to enhance oxygen bonding and saturation of fuel that promotes almost complete combustion. Complete combustion of fuel will result to extra mileage, great smoke reduction and better engine power and performance. We only combust about 70-80% of our fuel and the 20% to 30% unburned fuel goes out in our exhaust pipes as wasted carbon or pollutants, but G-MAX Device will maximize your fuel to 99% combustion.
    Gmax Supercharged Sir/Mam G-MAX FUEL SAVER is a one time investment that can give P10,000. to P 20,000. yearly fuel savings with the benefit of preventing gunk and corrosion inside your engine, it ads power and help reduce carbon emission by at least 50%. The price is P 9880. and the product pays itselt in less than one year, a good investment for a lifetime benefits.
    We have already installed hundreds of G-MAX Device to major car brands and models with gasoline and diesel fuels and it has proven the following:
    1. Saves fuel consumption up to 35%
    2. Reduce Emission up to 84% (w/ docs.)
    3. Increase Horsepower and torque.
    (Dyno tested)
    Aug 2004
    Bwahaha!
    "Monopole"... that's science fiction. Anybody who can create a monopole and market it for just a few thousand bucks could sell the technology for billions.
    And it still doesn't change the fact that fuel isn't magnetic.
    Jun 2008
    Pareho lang ba yan sa high max turbo simulator? Nabasa ko dati sa news paper na supported ng DOST itong Filipino invention.
    Sent from my Lenovo A7000-a using Tsikot Forums mobile app
    Bwahaha!
    exactly. i remember those clowns who claims that their coffee in sachets(nga ba?) could save fuel by simply sticking it with your gas tank
    sorcery!
    Quote Originally Posted by benchman View Post
    sorcery!
    And you can also wrap it around electrical cords to save on electricity.
    I can't for the life of me figure out why anyone would believe such claims.
    Jul 2013
    Take it from someone who experimented with these 'devices' for many months. Indeed, magnets work but up to a certain degree. The max fuel savings we got from magnets (from UK) is 10%. (for gasoline and diesel). The engine will also run smoother.
    Theres a catch in using a magnetic device. First, it is heavy (1/2k and up). It does not work immediately. You have to use it for up to 100km or more for you to feel the improvement. Fixed field magnets works but a weaker but pulsing field works better, e.g., a special solenoid with currents around 60ma * 12v is the best option. Pls see: nuvisys.blogspot.com for particulars.) Note: this is a patented device.
    Jul 2013
    Bwahaha!
    Sir, I was in contact with an employee last year that is making monopole magnets. He taught me how to make monopoles and I found the magnets to be extremely strong, much stronger than alnico/ceramic/etc. ones. The only drawback is the weight. Min weight is 1/2k. There will still be the problem of residual magnetism which could be bad if it affects the comp.
    And, is a monopole magnet science fiction? Madali namang gawin ito. They are so strong that you could hurt yourself making them from ordinary magnets, esp the large ones from china.
    Aug 2004
    Quote Originally Posted by pyramid00 View Post
    A monopole has one pole. It isn't possible to fabricate one outside of a particle physics laboratory, and even then, it takes a tremendous amount of energy.
    All magnetic fields loop. Even if you build a sphere out of magnets with only one pole facing out, the field will find a way to either link up with itself or the forces will cancel out.
    Whatever you're building, it isn't a "monopole" and you're using the terminology incorrectly.
    Also, you would actually need to crack open your ECU and run the magnet back and forth over the board to actually damage anything.
    Apr 2016
    Sinubukan ko din mag search sa internet tungkol dito pinanood ko pa nga sa youtube. Mythbusters, pero as expected nothing changed.... Same pa din yung consumption... Meaning MYTH BUSTED..
    Jul 2013
    Take two neodimium magnets, Put a plate between them. E.g. Join the two magnets together; south to south with the plate in-between. This is what they call a monopole. Maybe, it should be called by another name. Since you mentioned that the magnets will not damage the ECU, is it enclosed in a faraday shield?
    Its nice to have someone who knows his physics. Tnx for the info. Have a nice day.
    Jul 2013
    The main reason why i believe that magnets could save fuel (up to a point). Maximum savings is within 8-10% per my experiments. Fxck the myth busters! They are controlled by vested interests : International Journal of Mechanical Engineering and Computer Applications (India) (1) Effect of magnetic strength on hydrocarbon fuel viscocity and engine performance (2) Reduction of harmful emissions from exhaust in internal combustion engine by application of magnetic field on fuel line, (3)
    Modification of spark ignition engine to hho engine using hho generator and its analysis
    Magnetic monopoles do not exist. Thats would violate Maxwells laws. Break a magnet in 2 and it will just form 2 magnets with north and south poles at either end.
    Sent from my P01MA using Tapatalk
    Jul 2013
    Yes sir, maybe it should be called by another name. see #14. The fact is, the strength of the magnets joined together S-S is much greater than the usual S-N coupling.
    Of course.
    Jan 2009
    If it's a genuine and functional technology, pinag-aagawan na ng car manufacturers yan. There's no conspiracy BS about them wanting you to spend more on fuel. In fact. it's the reverse. Car manufacturers are battling it out, neck-to-neck, to advertise and sell vehicles that has cleaner emissions and more fuel-efficient than their competitors.
    Eh diba, kaya nga nasira VW, dahil sa pandaraya nila na palabasin na "Clean Diesel" mga TDI nila? Kung totoo yung mga gadgets na ito, lahat ng sasakyan, meron na.
    Jul 2013
    Sir OJ88, Pls research: ijmadotcom, go to achieves (1) vol 1, no 7 (2013) - effect of magnetic field on fuel and engine performance
    (2) vol 2, no 2 (2014) Reduction of harmful emissions in Internal combustion Engine
    (3) vol 2, no 2 (2014) modification of engine to HHO
    (4) vol 3, no 2 (2015) Ionization by magnetic field
    If you say that this is BS, email ijmadotcom and tell them what's on your mind.
Magnafuel review?
