Results 31 to 40 of 77
Tsikot Member Rank 4
- 1,842
June 7th, 2005 08:35 PM #31i drove a 04 city and it reaches 140 with not much of a problem. Weight is a factor pag mga 1.3
June 7th, 2005 08:47 PM #32
for highway and city cruising, ok lang. kayang mag140kph ng lancer EL sa star tollway. pero ang ingay na ng makina. ramdam mo na rin hirap na yung makina sa akyatan (pagsanjan-pakil-teresa-antipolo route). sobrang taas ng slope!!
Tsikot Member Rank 3
- Aug 2004
- 2,452
June 7th, 2005 09:24 PM #33Originally Posted by OTEP
compared to a 1.3li's measly 10-11Kg-m. anyway as not to get side track with the issue at hand. i drove a Corolla XE before for about a week going upto Tagaytay,etc. it was decent enough when cruising. but it was pretty gutless with 3 or more passengers going uphill. And yes todays' modern 1.3li multivalve, fuel injected, variable valve timing it should do just fine.
June 7th, 2005 09:32 PM #34
It may not seem like a good comparison, but in actual driving, you'd be surprised how much faster a 1.3l sedan is than the aforementioned vehicles. If I'm not mistaken, a Corolla XL is still faster (in acceleration) than both the gas and diesel Terrano as well as the GEN II and GEN 2.5 Pajero.
I'm just driving at the point that 1.3 sedans are far from hopeless on highways as there are even slower vehicles out there. The diesels are even slower once you reach highway speeds.
- Oct 2004
- 139
June 7th, 2005 09:39 PM #35bottomline is: know the capabilities and limitations of your ride to get the best out of it
- Aug 2004
- 243
June 7th, 2005 10:34 PM #37
Naka 2005 Nissan sentra GX (1.3 a/t) si mrs. and you'll be surprised what the overdrive feature can do...ok naman ang acceleration you wouldn't feel na you're driving a 1.3 pag naka o/d off, but...syempre may but...pag naka o/d na sa expressway and may sakay sa likod, sp. kung tatlo, mabagal talaga...City driving (o/d off), it's ok...pwede na....fuel efficient pa....
Last edited by fakesaint; June 8th, 2005 at 10:00 AM. Reason: balixtaddd o/d and o/d off post...
- Jul 2004
- 1,540
June 7th, 2005 10:43 PM #39Originally Posted by fakesaint
June 7th, 2005 10:44 PM #40
Never drive with the O/D off. Overdrive is your 4th gear. Would you drive at expressway speeds in third?
O/D is not a speed-boosting feature. It just allows you to cruise at a more relaxed rpm than you would if you had it off. It is called overdrive because the gear ratio is <1.00. It is equivalent to the fourth gear of a manual. I think on a Sentra auto 1 and 2 are underdrive, 3 is direct drive (1.00 gear ratio) and 4th is overdrive.
There is no reason to turn it off unless you want to prevent the vehicle from upshifting (e.g. climbing or descending steep mountain roads).
Otherwise leave it on (that's why it warns you in big yellow letters when you turn it off).
see my pahabol statement above. i mean, i can go on vacation anytime. but my spouse has her...
Traffic!
