Results 21 to 30 of 71
September 30th, 2010 07:50 PM #21
- Dec 2008
- 6
October 3rd, 2010 06:21 AM #22The new orange, red, and blue coolants are not compatible with common green and yellow coolants. Actually, they're not compatible with each other. We should only top-up with same color/type coolant.
Alternatively, if you really want to use the new coolant, the old coolant should be flushed and thoroughly replaced with the new coolant.
One last bit of info, newer red or orange coolants are usually for aluminum type radiators only. They'll damage copper and brass radiators.
- Mar 2010
- 301
January 18th, 2011 08:50 PM #23Good Day. I'm planning to replace coolant for "my" Innova. Alin sa gas station coolant ang ok, Shell, Caltex or Petron? Thanks in advanced to all fellow tsikot.
January 24th, 2011 06:13 PM #24
im using petron coolant sir but not distilled water, too bad...
ano kaya maging effect nito?
January 24th, 2011 10:17 PM #26
Dear Sirs:
I recommend using just pure distilled water (or something like Absolute pure drinking water - as it is vacuum distilled) with little or no 'coolant'.
Probably the only other coolant I would recommend would be ethylene glycol mixed about 50/50 with water.
The combination has both a lower freezing point than either (not really that important in the Philippines) and a higher boiling point than either pure ethylene glycol or water alone.
You can also add 5 to 10 ml of something like the old Shell blue 'coolant' that becomes milky when mixed with water - it will help prevent rust - do NOT use the whole container.
I believe that most 'wetting' products merely reduce the surface tension of the water - which honestly can be done by a teaspoonful of any strong liquid detergent - check out Wikipedia on 'surfactants'.
Oh BTW - Never, never use tap water in your radiator.
Best Regards,
Dusky Lim
- Nov 2010
- 45
January 26th, 2011 03:44 AM #27Pano po mag-flush o magtanggal ng water sa radiator? sorry newbie lang.
- Mar 2010
- 301
February 1st, 2011 06:04 PM #28
February 3rd, 2011 09:47 PM #29
Dear eat:
In most radiators, there is a drain plug on the bottom that can be reached from underneath the radiator.
It is usually a metal or plastic screw with a rubber washer. You can loosen it with a pair of pliers but be gentle - or you may break it.
To drain the radiator, WAIT TILL THE ENGINE IS COLD, then remove the radiator cap and loosen (do not remove) the drain plug, it usually has a slot cut in it to facilitate draining after it has been loosened a few turns.
The best and safest way to flush your radiator is to just add a pure distilled water like Absolute and then drain 1-2 liters away every weekend when the engine is cold.
Refill with more distilled water to make up for the amount you flushed - remember to fill the overflow reservoir too.
Because it has no minerals, the distilled water will slowly dissolve dirt and minerals (scale) that has built up in the engine.
Flushing out some of that, 1-2 liters will, over maybe a year will inevitably carry out most of the stuff.
Hope this helps.
Best Regards,
Dusky LimLast edited by duskylim; February 3rd, 2011 at 09:51 PM. Reason: bad spelling
- Nov 2010
- 45
February 8th, 2011 02:15 AM #30
Kung walang spare tire, invest on a Inflator kaysa sa sealant. Inflate the flat tire +10 psi than...
Liquid tire sealant
