Page 4 of 4 FirstFirst 1234
Results 61 to 71 of 71
    Jan 2011
    #61
    Kindly expound on this? I have been using Caltex Poison and no problem so far. Also, it says in their label na its ok for all types of radiator. I'll check pala the package later tonight.
    Yan ang sinabi ng kaibigan kong puti na mekaniko kaya di ko inihahalo ang kulay pula.Hindi rin ako chemist para malaman kung alin ang totoo.I just trust him.Well,mas maalam sya sa akin kaya lagi ko syang pinakikinggan.He can also a blind leading the blind.
    #62
    ang alam ko, bawal paghalo ang iba ibang kulay, kung red, red ulit ilalagay ko. green, green ulit...
    Quote Originally Posted by dagol View Post
    yes agree ako na 'wag ipaghahalo. Concern ko yung red color kung bakit di okay. Hindi naman siguro ibebenta yan ng Caltex if defective. hehe
    Yung OEM color ng Toyota coolant AFAIK kulay red din.
    #64
    because caltex is the toll packer for toyota.
    Jan 2009
    #65
    Color has nothing to do with coolant performance or compatibility. It's just a dye mixed with the coolant chemical to easily identify leaks in the system.
    Ideally, use only a coolant type that is appropriate for your vehicle or as indicated by the owners' manual.
    #66
    sir, kasi diba the color of the coolant is the identifier kung what kind of coolant it is?
    i might be wrong.
    Jan 2008
    #67
    How about tubig from ulan? is it okay?
    Jan 2009
    #68
    i might be wrong.
    It's just one way to differentiate coolants. But even if the coolants were of the same color, it does not mean they're compatible.
    http://www.search-autoparts.com/sear...27/article.pdf
    Aug 2009
    #69
    Sa prestone coolant po..nakasulat dun na pwede ihalo any brand any color...pero kung may pera ka at magkano lang naman.idrain mo na lang lahat yung dati tapos palitang ng bago...
    Jan 2008
    #70
    Guys.. Tubig from ulan ba okay lang lagay sa radiator?
    Aug 2008
    #71
    Quote Originally Posted by racer$7 View Post
    As other posts on this thread mention, use coolant mixed with distilled water. Rain water is highly variable in mineral content, depending on what is in the atmosphere at the time it rained, how long it rained, what location the rain is at, etc.
good engine coolant
