Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 71
    Aug 2005
    #21
    Quote Originally Posted by b16sir_stock View Post
    tanong lang mga sir... my vehicle is running without coolant eversince.
    do you recommend that i put one na or stick to current na distilled lang nakalagay.
    just worried kasi baka magloko if ever maglagay ako and also thinking (pwedeng mali pi ako) na since matagal na sya medyo mas mainit na ang engine nya at kailangan na lagyan ng coolant.
    kung wala pang kalawang ang tubig, ok na ok na gumamit ng coolant.
    pag may kalawang na kasi dapat ma flush out ang kalawang muna bago gumamit ng coolant. possible kasi na magbara kasi ma loosen up ng coolant ang kalawang then possible na mag develop ng leaks.
    Dec 2008
    #22
    Quote Originally Posted by youngrider View Post
    One time nag top ako ng orange coolant sa green coolant, ayun nagkaroon ng gelling.
    As a precaution I do not mix two different brands of coolant.
    The new orange, red, and blue coolants are not compatible with common green and yellow coolants. Actually, they're not compatible with each other. We should only top-up with same color/type coolant.
    Alternatively, if you really want to use the new coolant, the old coolant should be flushed and thoroughly replaced with the new coolant.
    One last bit of info, newer red or orange coolants are usually for aluminum type radiators only. They'll damage copper and brass radiators.
    #23
    Good Day. I'm planning to replace coolant for "my" Innova. Alin sa gas station coolant ang ok, Shell, Caltex or Petron? Thanks in advanced to all fellow tsikot.
    Jan 2010
    #24
    im using petron coolant sir but not distilled water, too bad...
    ano kaya maging effect nito?
    #25
    I`m using Red line Water Wetter .
    #26
    Dear Sirs:
    I recommend using just pure distilled water (or something like Absolute pure drinking water - as it is vacuum distilled) with little or no 'coolant'.
    Probably the only other coolant I would recommend would be ethylene glycol mixed about 50/50 with water.
    The combination has both a lower freezing point than either (not really that important in the Philippines) and a higher boiling point than either pure ethylene glycol or water alone.
    You can also add 5 to 10 ml of something like the old Shell blue 'coolant' that becomes milky when mixed with water - it will help prevent rust - do NOT use the whole container.
    I believe that most 'wetting' products merely reduce the surface tension of the water - which honestly can be done by a teaspoonful of any strong liquid detergent - check out Wikipedia on 'surfactants'.
    Oh BTW - Never, never use tap water in your radiator.
    Best Regards,
    Dusky Lim
    #27
    Pano po mag-flush o magtanggal ng water sa radiator? sorry newbie lang.
    #28
    Quote Originally Posted by duskylim View Post
    Dear Sirs:
    Best Regards,
    Dusky Lim
    Wilkens Distilled Water. OK rin at safe pa.
    #29
    Quote Originally Posted by eatmylens View Post
    Dear eat:
    In most radiators, there is a drain plug on the bottom that can be reached from underneath the radiator.
    It is usually a metal or plastic screw with a rubber washer. You can loosen it with a pair of pliers but be gentle - or you may break it.
    To drain the radiator, WAIT TILL THE ENGINE IS COLD, then remove the radiator cap and loosen (do not remove) the drain plug, it usually has a slot cut in it to facilitate draining after it has been loosened a few turns.
    The best and safest way to flush your radiator is to just add a pure distilled water like Absolute and then drain 1-2 liters away every weekend when the engine is cold.
    Refill with more distilled water to make up for the amount you flushed - remember to fill the overflow reservoir too.
    Because it has no minerals, the distilled water will slowly dissolve dirt and minerals (scale) that has built up in the engine.
    Flushing out some of that, 1-2 liters will, over maybe a year will inevitably carry out most of the stuff.
    Hope this helps.
    Best Regards,
    Dusky Lim
    #30
    Dear eat:
    Hope this helps.
    Best Regards,
    Dusky Lim
    Thank you sir! Sana lang madaling abutin ung drain plug sa AE92.
    Jan 2010
    #31
    Dear eat:
    Hope this helps.
    Best Regards,
    Dusky Lim
    im using petron coolAnt sir, when i travel from visayas to mindanao(almost 900kms), it makes my overflow reservoir empty sir... i always check my radiator yet it is intact and no holes... is there somethimg wrong with my radiator sir?
    Jan 2009
    #32
    Pure distilled water is not enough.
    A proper coolant is used for four reasons:
    1. The insides of most cooling systems may employ dissimilar metals. In which case, corrosion will still occur even if the water is virtually clean. Specific coolants with the correct ratio of anti-corrosive chemicals are used to prevent or slow down this process. These chemicals are also called inhibitors for good reason.
    -If ignored, a layer of corrosion (scales) will build up in time (engine block and radiator), reducing the system's heat transfer efficiency. It may eventually cause the cooling system to fail, giving you frequent overheating problems.
    2. Most water pumps require lubrication. Again, the correct type of coolant will prevent the pump seals from "drying out" when using the wrong coolant type or plain/distilled water.
    - If ignored, water pumps won't last as long as it should and would start to spring a leak.
    3. Coolants are formulated to have a higher boiling point than plain water. It helps prevent localized engine hot spots as well as reduce the amount of fluid evaporation.
    - If ignored, the cavitation caused by the boiling liquid will introduce hot spots (uneven heating) and may cause pre-ignition under certain conditions.
    4. For its anti-freeze properties, though applicable only in countries with icy climates. It prevents the liquid from well, icing, and destroying the water pump upon starting.
    AVOID using tap water or filtered water. If a suitable coolant is not available, distilled water can be used as a temporary substitute. Drain and replace with a recommended coolant immediately.
    So what is the recommended coolant? This is important. OEM is BEST, period. As with No. 1 and No.2 above, there's a right balance or ratio of anti-corrosive chemicals as well as the required lubricant for the pump. Using the wrong coolant type will actually accelerate corrosion and/or kill the water pump! Take away the guess work and buy only the OEM coolant prescribed for your vehicle.
    #33
    Quote Originally Posted by nvidi.turion View Post
    check your rad cap. might be the springs are not working anymore.
    happened to me before.
    Jan 2010
    #34
    what u mean radiator cap sir(spring)?... mahigpit pa din yung cap ng radiator ko sir, i always open and check to make sure na my laman p sya...
    May 2009
    #35
    Some useful reading for the benefit of all motorheads:
    http://www.usmotors.com/products/ProFacts/tableof.htm
    #36
    baka mukhang ayus pa yan, pero hindi na nagh-hold ng pressure.
    yan usually sira ng rad cap. nagbabawas ng tubig pero wala naman tulo.
    Jan 2010
    #37
    ok pa yung rad cap ko sir(masikip pa kasi sir) but i dont know kung nagho-hold p siya ng pressure...
    #38
    you can not check your rad cap visually. pressure test yan. kung natutuyuan ka ng water, either may leak, or sira rad cap mo. worst case scenario, blown head gasket kaya nauubusan ka ng tubig.
    Jan 2010
    #39
    not all the time naman sir natutuyuan ako ng tubig sa overflow reservoir, siguro pagmalayuan na yung biyahe ko saka ako natuyuan sir...
    #40
    Try replacing the radiator cap for now, mura lang naman yon and a very basic fix, if that's not the problem, then meron ka nang spare cap j/k
good engine coolant
