Results 61 to 70 of 71
- Jan 2011
- 123
April 5th, 2011 03:45 AM #61
April 5th, 2011 11:47 AM #62
ang alam ko, bawal paghalo ang iba ibang kulay, kung red, red ulit ilalagay ko. green, green ulit...
April 5th, 2011 11:57 AM #63
Fasten your seatbelt! Or else...Driven To Thrill!
April 5th, 2011 12:15 PM #64
April 5th, 2011 01:03 PM #65
Color has nothing to do with coolant performance or compatibility. It's just a dye mixed with the coolant chemical to easily identify leaks in the system.
Ideally, use only a coolant type that is appropriate for your vehicle or as indicated by the owners' manual.
April 5th, 2011 01:30 PM #66
April 5th, 2011 02:03 PM #68
It's just one way to differentiate coolants. But even if the coolants were of the same color, it does not mean they're compatible.
http://www.search-autoparts.com/sear...27/article.pdf
April 5th, 2011 04:34 PM #69
Sa prestone coolant po..nakasulat dun na pwede ihalo any brand any color...pero kung may pera ka at magkano lang naman.idrain mo na lang lahat yung dati tapos palitang ng bago...
Had my 2014 Altis repaired by Tireman PH in Gen. Trias, Cavite last Wednesday. Nawala na yun...
rack and pinion repair
