Results 51 to 60 of 71
March 17th, 2011 01:25 PM #51
50% coolant + 50% distilled water (Wilkins, absolute). for example. 5 liters yung coolant tank: 2.5L pure coolant + 2.5L distilled water. Make sure the coolant is pure kasi meron na ata binebenta na pre-mixed with water na.
- Sep 2010
- 70
March 17th, 2011 01:31 PM #52
Tsikot Member Rank 4
- Jun 2006
- 2,605
March 17th, 2011 01:53 PM #53Dont know how much you will need. I use Petron coolant for my car. Instruction says mix 500 ml petron green coolant with 1.5 liters of distilled water (3:1). So it will give you 2 liters. I think 4 liters of the mixed stuff should be enough. Petron coolant is about 125 pesos from Pertron gas stations.
Toyota sells premixed pink coolant. It comes in 2 liter bottles. Less than 200 a bottle.
Preston is also good for your car. They have both concentrate and premixed versions. Cant remember how much.
- Sep 2010
- 70
March 17th, 2011 02:39 PM #54i see, thank you sir!!
will try na lang muna petron mixed with distilled water, since katabi lang namin station
sir ask ko na din po,in preparing the solution,what needs to be put first?tama po ba procedure na gagawin ko?pls evaluate:
- drain the radiator solution from the drain plug under
- put the 1 part solution(if will use the petron coolant)
- put the 3 parts distilled water
- refill the coolant tank reservoir with distilled water
Sir,if i will DIY,how will i remove the residue or sludge if there's any in the tank?
thank you!
March 17th, 2011 04:51 PM #55
minimal corrosion lang naman sa aluminum at cast iron ang epekto ng ethylene glycol...usually kung may nagleak, hindi compatible yung rubber parts or 0-rings sa water pump, etc.....we have the green, purple and pink coolants. they serve different carmakes usually but still the same purpose of raising the boiling point and lubricating the cooling circuit (prevents rust).
March 17th, 2011 08:58 PM #56
I use prestone coolant.di naman nagkakaleak etong dalawang car namin,hinalo ko pa nga sa toyota coolant.may nakasulat naman sa lalagyan nya kung pwede o di pwede ihalo.780pesos atan bili ko sa ace for 1gal.
March 30th, 2011 12:10 PM #57
just bought Caltex coolant. 392/L mahal na pala.
I just noticed na iba na packaging nila ngayon. May malaki ng nakalagay na Poison sa front. Can I still mix this with the old Caltex coolant?
- Jan 2011
- 123
April 4th, 2011 07:39 PM #59
Had my 2014 Altis repaired by Tireman PH in Gen. Trias, Cavite last Wednesday. Nawala na yun...
rack and pinion repair
