Results 41 to 50 of 56
July 9th, 2015 08:20 PM #41
Agree. Medyo kakatakot mag pa engine wash. Best tip is make sure alam nila ginagawa nila. Based on experience they usually cover the computerbox,alternator. Tas they use spray never stream when washing any part of the engine.
Heres a sample one done by qzone, thats where i have mine done on an annual basis.
July 9th, 2015 09:19 PM #42
personally bihira tayong magpa engine wash every 2 to 3 yrs lang pero sa underwash regular twice a year sabay check na din after wash kung may kinakalawang sa pang-ilalim sabay apply ng rush converter.
July 10th, 2015 09:49 AM #44
Daming engine cleaners/degeasers. I bought megs engine cleaner. Daming youtubes how to use it. Daming options.
- May 2011
- 227
July 10th, 2015 12:48 PM #45Done mine in petron north fairview engine at under wash un pinagawa ko gumamit sila ng gaas to remove un mga build up oils sa ilalim at sa engine the water pressure tapos sinabunan tapos water pressure again tapos to make it dry air pressure until maDRY so far so good naman pina test pa sakin na working at walang problem un car after they clean it less than 400php lang gastos ko kasama na tip nila btw ang maganda dun , ay lifter sila for the under wash and then un gaas is pressure din un ginawa ayun so far no problem naman feeling gumaang un ride ko dahil sa under wash siguro nawala un mga dumi haha
July 10th, 2015 01:27 PM #46
- Mar 2014
- 901
July 10th, 2015 11:41 PM #47That is the usual procedures naman when undergoing engine and underwash in gas service stations. Tinatakpan/bilutan pa nga nila ng basahan at plastic yung distributor assembly bago nila i-washed engine bay. Then they dry it off with pressurized air. Layo nga lang sa area ko. [emoji4]
Sent from my UP+ using Tapatalk
July 11th, 2015 12:16 AM #48
ako wala pa naman naging problema sa engine wash. degreaser spray (marami sa diy) at brush lang katapat. dati nag-aalangan din ako na mabasa yung alternator at sensors pero lately di ko na binabalutan ok naman. yung air intake lang tinatakpan ko pero kahit wala na takip, kapag napasukan naman ng konting tubig, dun pa sa air box papasok, punasan na lang bago paandarin. kapag na dry na, konting pahid ng dressing malinis na ulit. normal pressure lang ng garden hose ginagamit ko. here's what i do, palamigin muna makina. spray degreaser the let it soak mga 2mins tapos agitate ng brush. wala akong detailing brush, ang ginagamit ko yung paint brush na puti yung bristles, itinali ko sa 1ft na stick para maabot yung hard to reach areas. kapag madikit yung mga natuyong oil at dumi, spray mo lang ng konti pang degreaser then padaanan ulit ng brush. then hugas na, padaloy lang ng tubig no need na lakasan yung pressure. tapos punas punas na, kung may mga tinakpan ka make sure na tinanggal mo na. then the moment of truth, paandarin mo makina para madaling matuyo, cross your fingers na walang check engine light
then kapag natuyo, pahid ng konting dresssing ayos na! i used 303 aerospace protectant o yung meguiar back to black hindi siya shiny. kapag gusto ko ng medyo shiny ay yung penetrating oil ng mitsu casa ginagamit ko
sinubukan ko rin yung nabasa ko na diluted na tire black 50:50 sa water ok din pero madaling kumapit ang dumi
- May 2011
- 227
July 13th, 2015 03:49 AM #49
- Jun 2015
- 21
July 13th, 2015 02:23 PM #50As long as na wala pa kumalkal sa mga wiring harness and elec connectors you don't have to worry cause all factory connectors and terminals are weather tight no need to cover the alternator as long as di mo sya ipapark ng matagal after you wash it kasi kakalawangin yong loob and it will seized
If you don't have a spare tire, a tire inflator using the socket of the car as power outlet is the...
Liquid tire sealant
