Results 1 to 16 of 16
    May 2005
    Hi guys!
    I need some advise. Yung 98 Corolla ko ayaw mag start. May redondo, pero walang spark sa hitension wires. This happened all of a sudden, without symptoms. Nag park lang ako, then nung aalis na ako, ayaw na. Everything was fine prior to this. Fuel pump was tested and found working fine.
    Here's what had already been done:
    1) First suspect was distributor. Dinala kay Rey Electrical, pinalitan ang pickup coil (wasak na, labas na yung mga strands), condenser (nag leak na), igniter (bumuka na) at rotor. Tested, working fine. Kinabit sa oto, wala pa din lumalbas sa wires.
    2) ECU. Was brought to someone who knows how to check, buo daw.
    Ano kaya next na dapat i-check? Any help will be appreciated. Thanks in advance!
    Sep 2004
    Silipin nyo rin timing belt.
    May 2005
    Yup, sinilip na. Binuksan kasi head just to be sure. Buo naman timing belt. No obvious issues nung binuksan ang head.
    Thanks!
    May 2009
    Quote Originally Posted by izzy View Post
    Hi guys!
    chineck ba ang voltage readings sa crank sensor?
    may similar experience ako regarding jan. non-toyota but efi so basically the same approach. after checking the fuel system, ignition coils and its associated wiring, chineck ko yung crank sensor. frayed wiring on the crank sensor as well as corroded connections kaya ayaw magkaroon ng supply voltage. no spark din that time.
    after the crank sensor e check din ang cam.
    Hi guys!
    Where is the car now? Nai-uwi mo pa ba after what had happen? Share us a picture of the engine.
    Sent from my UP+ using Tapatalk
    Jun 2011
    Na try na ba diagnostic mode?may error code naman na lalabas just in case sensors or sa ecu ang problema.d gaano ka complicated i diagnose ang 4afe.Wag k lng makaka chamba ng mekaniko na kamag anak ni madam auring.hehehe.
    May 2005
    Quote Originally Posted by pdspd View Post
    Hehehe! Palit mekaniko na nga muna ako eh. Mejo bisi lang last week kaya di naasilkaso. Bukas, papuntahin ko na bagong mekaniko.
    May 2005
    Just found the specs for the 4AFE ignition coil.
    Ignition Coil
    5. INSPECT PRIMARY COIL RESISTANCE
    Using an ohmmeter, measure the resistance between
    positive (+) and negative (–) terminals.
    Primary coil resistance (Cold):
    1.1 ~ 1.7 at –10 ~ +40°C (14 ~ 104°F)
    If the resistance is not as specified, replace the ignition
    coil.
    6. INSPECT SECONDARY COIL RESISTANCE
    Using an ohmmeter, measure the resistance between the
    positive (+) and high–tension terminals.
    Secondary coil resistance (Cold):
    9 ~ 15 k at –10 ~ +40°C (14 ~ 104°F)
    If the resistance is not as specified, replace the ignition coil.
    Check ko yung sakin. Baka nga ignition coil.
    Thanks!
    Feb 2009
    Thanks!
    Sometimes it passes the resistance check but fails miserably on spark test. The coil should be able to snap a bluish white spark from 3 inches to ground when tested. If the spark happens around the coil, the insulation had been breached
    Feb 2005
    Hi guys!
    bakit hindi isinama yung ignition coil sa mga pinalitan? although walang physical evidence na may sira sya pero baka naman po mahina na buga ng kuryente? and how was the distributor tested? kinabit ba sa ibang kotse? I'm, asking these questions kasi nangyari sakin yang ganyan (pero carbed oto ko) puro redondo lang... and the culprit was the ignition coil, ok sya pag tinetesting (spark test) malakas daw ang spark sabi sa shop (di ko na sasabihin kung anong shop) pero pag kinabit na ayaw magstart ng oto.
    palit igniter, condenser etc., katulad ng ginawa sayo except for the ignition coil (kasi nga ok pa daw), ayun umandaw ng isang araw after that ayaw nanaman umistart. Balik nanaman sa shop, kuntodo testing ng kung ano-ano at napaandar naman ulit nila but sadly paguwi ko ganon nanaman!
    so i decided na yung mekaniko na lang palitan ko. Nagikot ikot ako (habang umaandar pa oto) sa buong metro manila and i chanced upon a small autoshop somewhere in kamias kamuning at nagtanong ako kung may mekaniko sila at papatingnan ko problema ng oto ko. Sa madaling salita sinabi na nya agad "sir palitan natin ignition coil nyo, mahina na po buga ng kuryente", so pumayag ako tutal yun na lang naman ang hindi pa napapalitan sa distributor ko. And eventually nasolve na starting problem ng oto ko, in fact one-click na sya, di tulad nung dati nakaka ilang pihit pako ng susi bago sya mag start...hth
    Jun 2006
    maybe wrong rotor? di umaabot spark from coil to distributor cap.
    May 2005
    Quote Originally Posted by box_type View Post
    Kasi nga ok pa daw. Tinesting nila Rey Electrical, malakas daw. Nakita ko, nag spark naman talaga.
    Then tinest din ng mekaniko na pinaikot daw yung distributor, may lumalabas naman daw sa wire. I didn't see this test personally, though.
    Kanina lang, shorted TE1 and E1, then turned on the key. Continuous blinking lang ang CEL. I guess that means ok ang mga sensors?
    Feb 2005
    imho, yung spark test indicator lang yan na may lumalabas na kuryente sa coil pero pag sinalpak mo na sa oto mahina naman buga ng kuryente, madaming beses nangyari sakin yan pag pinatesting ko yung coil via spark test ok daw malakas daw spark pero pag kinabit na sa oto ayun... nganga
    Baka namali ang firing order. Happened to my ST191 before. Nabiligtad ng mekaniko yung pin ng distributor.
    To test, bukas ng valve cover, itapat yung crankshaft pulley notch sa zero, ensure that no.1 cylinder is at compression TDC by ensuring that the pointed part of both its intake and exhaust camlobes ay nasa horizontal position or hindi nakaturo sa ilalim. At this position, yung distributor rotor e dapat nakaturo sa HTW ng no. 1 cylinder.
    Or try to test kung may voltage sa terminals ng fuel injectors. Troubleshooting a Toyota Fuel Injector | eHow
    Feb 2009
    i have used this on ignition performance diagnosis, it has never failed me.
    http://www.chevelles.com/techref/hei_files/image010.jpg
98 Corolla 4AFE no spark
