Page 1 of 118 123451151101 ... LastLast
Results 1 to 20 of 2351
    Sep 2006
    I would like to help! Throw in your questions regarding problems with your fuel systems (injection pumps/ injectors/ turbochargers/ electronic systems/ etc.....) Then you guys take it from there...................if I can be of help, why not!
    Dieseldude, how will I know if a Turbo is Watercooled or Oilcooled? and can one install a watercooled turbo with an oilcooler? and how?
    Sep 2006
    Hi Rion,
    All turbos are cooled and lubricated by the engine's lube oil. Aside from oil supply and drain lines, a water cooled turbo will have coolant supply and drain lines as well. Plumbing will often be attached to the center housing, near the oil lines. On high load applications, coolant is sometimes plumbed to the turbine housing, and the turbine housing will have the necessary fittings.
    You don't have to install an oil cooler.
    An air intercooler may help. This is located between the turbo's air discharge duct and the engine's air intake manifold.
    I hope I have been of help to you. Good luck.
    Apr 2005
    Hi Dieseldude,
    I'll repost a hanging question i have on the other thread regarding preventing fuel injection problem, specific on the Patrol GU:
    Quote Originally Posted by Boy Torotot View Post
    So any other tips to help avoid this fuel injection problem in the future? Here are some of the suggestions deduced from above posts:
    1) regularly change fuel filters
    2) fill up only in stations known for their clean fuel
    3) do not install any fuel saving device
    4) sell your patrol
    Anything else? How about using Biodiesel, could this cause fuel injection problem?
    Sep 2006
    Hi Boy Torotot,
    Check out my comments posted under the "Home-made Biodiesel"thread which I posted last September 24.
    Your suggestions are OK, but I would like to add that when you replace your Fuel filters go for the Original (critical for this new models) not the replacement filters.. I am not selling for Nissan, but I have seen quite a number of problems when a replacement brand is used. Why scrimp on the cost when you do not spend this kind of money everyday for your vehicle!
    Apr 2005
    Thanks sir! Will check your comments right away.
    I've been using the original fuel filters, and having it replace regularly at the casa, since i got my ride. So they should be using original filters and not replacements.
    Quote Originally Posted by Dieseldude View Post
    does it mean that my turbo is both Watercooled and Aircooled. may IN-OUT kasi yung water and oil paths sa Turbo...
    and does it need a turbo timer?
    thanks, may spare toyota 3c-tdi engine kasi kami, baka puwede ilagay sa aming 3c-td. hehe..
    Oil is primarily for lubrication, water is primarily for cooling.
    I'm still a bit confused sir Otep, other peeps differentiate the two... is there a Watercooled Turbo only and an Oilcooled only?
    Sep 2006
    Quote Originally Posted by rion View Post
    If your turbo has oil and coolant plumbing, it is oil and water cooled. Oil primarily lubricates the turbo. Oil has a secondary function of cooling the turbo as heat energy is transferred to the oil, and further dissipated to the engine. Water cooling is sometimes integrated into the turbo design if it is expected to be used on high hp engines (more hp = more fuel = more heat).
    A turbo timer may help. However, if the original design doesn't have it, you don't really need it. So why spend more?
    Pwede rin if you want to try.
    Sep 2006
    As all turbos are always oil lubricated, they would therefore be oil cooled as well.
    However, not all turbos are water cooled.
    See my post to Rion regarding water cooled turbos.
    does the starex TCi hav both?
    Sep 2006
    I'm not sure if Starex TCi is both oil and water cooled. What is TCi?
    What's the year and engine model of your starex?
    I can check this out when you send me the above info.
    Bye
    Jul 2006
    yung Innova D4D ng brother ko -- oil cooled lang yung turbo
    yung Everest ko naman -- oil and water cooled yung turbo nya
    i'll post pics later para makita nyo yung difference.
    now I get it. thanks Dieseldude.
    sir JagXtrm, though now I think I can differentiate them. but I would still like those turbos. thanks
    Jul 2006
    bro rion,
    sorry, di ako nakapag-pictorials kagabi. brownout eh, sobra dilim!
    i'll try again mamaya after office.
    TCI is turbocharged, intercooled. Same engine as the 4d56 of the GEN II Pajero.
    Not sure about turbo cooling on the Starex, but the GEN II Pajero has both oil and coolant lines to the turbo.
    Sep 2006
    Hello to all my Tsikot buddies,
    Just read your responses, and also your private messages. Sorry for the delay. We lost power and our telephone lines since last thursday. Got it all back only today. Bayantel lines still down. Only PLDT lines are back in my office.
    Give me a little time to collect my thoughts and finish with my backlog at work. Your comments, questions and thoughts are always welcome. Just keep them coming and I will get back to all of you.
    Many thanks guys,
    Dieseldude
    DieselDude at mga Expert Guys,
    kacheck ko lang sa spare Toyota 3C-tdi engine namin, hindi pala kasama yung Intercooler(Radiator/condenser) ba tawag nyan?
    anyways, mukhang simple lang pala... I think... you just connect from the Turbo output, then out to the intake right?
    Turbo-to-Intercooler-to-Intake
    then how much would a Surplus intercooler cost? ano kaya ang brand na pinaka smallest or the most thin/compact cooler? Surplus lang siguro ang bilhin ko kasi mura at pang experiment/fun lang.
    at okey po ba ilagay siya sa ilalim ng van? just 5-8 degrees, at lagyan lang ng protection against rocks and hard surface just like our Aircon's condensers are located...
    ilustrated in this 1 minute drawing from photoshop:
    Lagyan mo ng cooling fan. Pwede naman iyan. Not optimum but feasible pa din.
Diesel Fuel Injection System Help Desk
